2001 cl pass window
Old Dec 9, 2014 | 07:13 PM
steve kelly's Avatar
Cool 2001 cl pass window
I have a 2001 acura cl and the pass window made a loud clunk noise and now wont roll down,it kinda sounds like the track rolls down but the window stays up. I was wondering if anyone has had this type of problem,before I tear it apart.
Thanks Steve
Old Dec 10, 2014 | 12:09 AM
BAGII's Avatar
The most common failure is the window motor/regulator; either the cable breaks or one of the plastic linkages. You won't know until you pull off the door panel. I think you got lucky cause most of the time, the window will just fall inside the door.
Old Dec 10, 2014 | 06:34 PM
thanks I will take it apart and see what the damage is
Old Dec 11, 2014 | 12:36 AM
BAGII's Avatar
Please, get back to us when you figure out what the issue is so that your information may help somebody else with a similar problem!
Old Jan 9, 2015 | 11:21 PM
truaznballa25's Avatar
awesome user
I just experienced the same exact issue but on my drivers side window. I already took it apart and found that the metal cables frayed inside of the motor. Based on how the whole assembly was designed, I believe I have to replace the track and the motor.
I will post pictures tomorrow if people are interested.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
