2001 CL No Start!
2001 CL No Start!
2001 CL Type S will not start!
Turning over, plenty of juice. Do not here fuel pump prime, nothing but 'silence'.
Checked fuel relay, looked fine, no cracks, soldering in good shape. (Should I replace anyway, possibly internal problem in relay?)
Should I buy scanner/diagnostic tool or go for the fuel pump?
Any advice is greatly appreciated.
If you are not throwing a code, then a scanner will not pick up anything from my experience...
are you having the same problem as me?
look at the thread i made just below yours on here....gl
No, not having all that craziness, but car was sitting for a day, then came out to start it, it ran for 1 second then died. Tried to start it again and now, nothing!
Weird
If you don't hear the fuel pump prime, it's most likely the relay. The Fuel Pump realy won't change in appearance. If it died, it died. I just went through this myself. Swap it and see. If it isn't the realy you can alway return the part!
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
