2001 Acura Cl p1753 Problem
Old Feb 1, 2010 | 11:26 AM
dpark1020's Avatar
4th Gear
I have a strange problem because it goes away and comes back. The D5 light blinks and I don't seen to have a 1st gear. The OBD came out to p1753, could you please help me find the TCM and if it was a fuse problem which fuses I would have to replace. And could this possibly be a problem with the torque converter? If so how can I repair this. Thanks much for your help.
Old Feb 1, 2010 | 12:15 PM
chris82079's Avatar
P1753 TCM A/T Lockup Solenoid Valve "A" Fault
I searched for a repair and got nothing! Maybe some one with a service manual can shed a little more light on this!
Old Jan 31, 2012 | 02:26 PM
watsonauto's Avatar
3rd Gear
I have same problem-This is on 02 acura tl type s.The D light blinks-It goes away and comes back-The code reads P1753 problem in torque converter clutch solenoid circuit-The problem is in the wiring or in the torque converter clutch solenoid valve(on top of transmission)-my was a bad ground-two ground points 1.end of transmission(0n the TL look through the wheel well) 2.Thermostat housing.
Zonian22
Nov 14, 2015 01:20 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
Mike Bertram
Sep 10, 2015 09:27 AM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
NSolace
Sep 3, 2015 08:02 PM
