2001 Acura CL No Fire, I'm stumped.
Old Dec 4, 2012 | 03:32 PM
bigerk's Avatar
The car turns over but doesn't start every time. When it does start, it dies after 10 or 15 seconds. I have checked for fuel pressure and it's good. I'm hearing a low buzz from the fuel pump and I've also remove the fuel line to verify it's working. I have put a timing light on one of the plug wires and I'm getting no fire to the cylinders when cranking. I'm getting a light when it's running ofcourse. I have also put a handheld scanner on it and I have no codes. I have read that the fuel injection relay under the driver's side dash can go bad and show the symptoms I'm getting but will it also kill the ignition?
I've also checked for a bad immobilizer and it seems to be working. The green key light on the dash goes out after I attempt to start the car. It blinks 4 times after I remove the key from the ignition and I've tried 3 different keys. So, now what? Any ideas?
Old Dec 5, 2012 | 09:57 AM
bigerk's Avatar
Well, I installed a new fuel injection relay this morning but the problem still exists. Something is disabling the ignition after start up. It seems the car will start after an overnight wait but after it runs for a minute it shuts off. After that it won't start for the rest of the day. Anyone have any other suggestions?
Old Dec 5, 2012 | 12:36 PM
Catfisha's Avatar
Giant Blue Car
Hmmm.....it may not be a fuel issue. Sounds more like the ignition switch is bad....
Old Dec 5, 2012 | 07:10 PM
bigerk's Avatar
It's funny you mention that because I'm leaning toward replacing it next.
Old Dec 7, 2012 | 09:11 AM
bigerk's Avatar
Installed the new ignition switch this morning and it did not help. I thought that surely would work. What else am I missing?
Old Dec 7, 2012 | 11:12 AM
Catfisha's Avatar
Giant Blue Car
Is your starter solenoid gear getting stuck to the flywheel/ring gear?
Old Dec 7, 2012 | 01:20 PM
bigerk's Avatar
No starters fine. I'm getting no fire to the plugs when cranking. Something is killing the ignition. Checked fuel pressure and its over 20psi. My gauge only goes to 20 and its pegged.
Old Dec 10, 2012 | 12:23 PM
Catfisha's Avatar
Giant Blue Car
Have you checked for any blown fuses in the box under the hood and under the dash on the driver's side?
I'll keep thinking about it......
Old Dec 10, 2012 | 12:39 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Could be your TPS
Old Dec 10, 2012 | 12:45 PM
Catfisha's Avatar
Giant Blue Car
I don't want to bring this up....BUT when was the timing belt replaced last?..
Old Dec 10, 2012 | 01:00 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Are you sure your not getting spark ?
Have you checked crank and cam sensors conectors maybe even the plugs at the ecu ?
Old Dec 10, 2012 | 04:54 PM
Catfisha's Avatar
Giant Blue Car
That's a good idea! A bad CKP and CMP (TDC) will jack up timing...just like a bad distributor/rotor....
Old Dec 11, 2012 | 03:58 PM
aznboi2424's Avatar
Are you a tech or something?
Old Dec 11, 2012 | 04:14 PM
Catfisha's Avatar
Giant Blue Car
No, but.....
Old Dec 13, 2012 | 11:30 AM
(Mid-Atlantic)
Old Dec 19, 2012 | 03:33 PM
aznboi2424's Avatar
That went over my head.
Old Dec 20, 2012 | 11:46 AM
Catfisha's Avatar
Giant Blue Car
You don't remember the stupid Mentos commercials?!
Old Dec 21, 2012 | 01:35 PM
aznboi2424's Avatar
Meh. Barely. The commercial looks pretty old, maybe I was in elementary school at the time
Old Jul 5, 2024 | 06:15 AM
TintGod's Avatar
I’m having the same issue with my 2001 CL S have been trying to figure it out since Sunday now.
Gabru678
Apr 24, 2019 02:36 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
