2001 3.2CL - Electronic trunk malfunction!! Help Please
Old Mar 6, 2007 | 11:23 PM
20mikeCL01's Avatar
Hey guys, my names mike and I own a 2001 3.2CL that has a trunk that wont open.
The situation:
-No fuse listed for the trunk, but checked all of the fuses and there all good.
-All electronics in car work EXCEPT the trunk button on drivers side door and on the key fab.
-Master swith in glove box is swithed to on posistion
-was told by a service tech that sometimes the master switch comes loose, so i took the glove box off and checked connection. still doesnt work.
Any Suggestions?????
Old Mar 31, 2007 | 10:12 PM
celynka's Avatar
Sundance Gold in
i put my bet on master switch, system is simple goes from sorce of power to master switch, trigger button to release solenoid. check voltage b4 and after each switch
Old Apr 1, 2007 | 02:34 PM
20mikeCL01's Avatar
Hey thanks, I'll give that a try when i get a chance and post the results.
Old Apr 30, 2007 | 04:29 PM
ch0wd0wn's Avatar
3rd Gear
I'm having the same exact problem, I've checked the masterswitch but its on. I toggle it and try but nothing happens. When I use the remote control to try to open the trunk..all I hear is an electrical click.. when I try the manual button on the driver door... nothing happens.. No sound..
how do I "check voltage" b4 and after? This happened after I coming home from my trip and I have bunch of stuff in the trunk! Is there a way to bring the seats down so I can retreive my stuff??? Any workarounds?
Old May 1, 2007 | 07:19 PM
celynka's Avatar
Sundance Gold in
I Guess In Your Case Your Latch Is Just Jammed Up Bc U Have Too Much Stuff In The Trunk. You Can Open It Manually. You Have That Little Access Door Behind Armrest Of Rear Passanger, When U Open It , In Top Left Corner Inside Trunk Look For Little Rubber Handle, Thats Manual Relese Handle. Should Solve You Problem
Old May 2, 2007 | 12:53 AM
ch0wd0wn's Avatar
3rd Gear
Oh man...AWESOME..I knew there had to be a manual release! Thanks so much for your help!
Old Jan 11, 2008 | 01:31 AM
FwC's Avatar
FwC
I'm having the same issue as chowdown. I can't open my trunk other than with the manual latch. I hear that click behind glove box when i use remote but nothing else seems to work. Suggestions, helpful hints, FIXES?
Old Jan 13, 2008 | 05:17 AM
FwC's Avatar
FwC
Nothing Eh?
baelim
May 10, 2018 09:53 AM
Pham Alvan
Mar 16, 2016 09:17 AM
NorthWestAnimal
Sep 28, 2015 06:20 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
