2-3 Shift Problem
Old Oct 26, 2008 | 12:18 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
2-3 Shift Problem
Hey guys, I've got a small problem with my CL and want some opinions/ideas. Its an 01 CLS on its 3rd transmission (latest replacement was January 07)... I've had the car for over a year, and only really noticed the problem last week because I haven't really raced past normal driving conditions much... Hell, only hit Vtec a few times... (blame autotragic paranoia)
In SS mode, under normal driving (shifting at low revs), the 2-3 shift is fine... But if I hit the throttle harder and try to shift it over 5K rpm, the car won't shift out of 2nd gear to 3rd unless i tap the shifter up like 3 or 4 times. At first I thought maybe I was doing something wrong, but its becoming more and more consistent. I'd say it does this about 50% of the time? I'm going drain/refill the fluid next weekend and see if that makes a difference. Any opinions or similar experience would be appreciated.
Please spare me the "shoulda gotten a 6spd" comments. I already know.
Old Oct 26, 2008 | 11:51 PM
celynka's Avatar
Sundance Gold in
Drain your tranny and change the atf filter. These slush boxes clogg it pretty well!
Old Nov 9, 2008 | 01:21 PM
uh... bump...
There's no changeable trans filter... There are screens that can be replaced, but they're inside the tranny...
Anyone got some better advice? I drained/refilled 3 quarts of fluid yesterday and the car does seem to be shifting a lot more smoothly but I haven't noticed if the 2-3 shift problem in SS has been fixed yet...
Old Nov 9, 2008 | 01:25 PM
YeuEmMaiMai's Avatar
take it back to acura and see if they will fix it....how many miles on it since the last replacement?
Old Nov 9, 2008 | 03:26 PM
Transmission was replaced January 2007, car had 115K miles on it. I purchased the car in October 2007 with 120K on it, Car currently has 134K on the clock. Transmission came with a 3 year 36K mile warranty from Acura. Is the warranty on the transmission transferable to me?
Old Nov 9, 2008 | 03:51 PM
should be, call them up and ask
Old Nov 9, 2008 | 09:53 PM
celynka's Avatar
Sundance Gold in
Originally Posted by disgruntlednut
uh... bump...
uh... bump
There is an atf filter, right on the top of transmission there is atf passage and atf coler/warmer - thats where the filter is located - looks almost like fuel filter - part# 25450-P7W-003. Restricted filter will cause significant pressure drop and transmission to jerk, slip Acura service advisors saying - its not servicable - its big fat BS and I changed it myself twice
Old Nov 10, 2008 | 07:48 AM
I'm reading mixed things... 95% of what I'm finding is saying there are only screens inside the transmission, but the part you listed exists.... soooo... wtf :-\
til I came across this? https://acurazine.com/forums/2g-tl-1999-2003-98/transmission-filter-598388/
celynka, the pictures listed in that thread... is that what you were talking about? Is the filter easily accessible? Has anyone else looked at replacing theirs?
Old Nov 17, 2008 | 04:49 PM
Quick update: Drained/refilled 3qts of ATF, shifts alot more smoothly and no problems at all...
Old Nov 20, 2008 | 04:28 PM
2K1CLtypeS's Avatar
Originally Posted by celynka
uh... bump
Thanks for the heads up celynka . Just ordered one today
Old Dec 4, 2008 | 03:15 AM
that will be short lived inprovement (ask me how I know)
Old Dec 7, 2008 | 07:33 PM
celynka's Avatar
Sundance Gold in
til I came across this? https://acurazine.com/forums/showthread.php?t=598388
I red that post and thats, in fact, filter I talk about. I do not want to dispute opinions of these guys and how the oil is redirected throgh the tranny, but I tel you one thing, I changed it, it was so clogged I couldnt blow through it - new one , no problem. It did immediately remove jerking an slipping and still running fine after 10 months. I agree it may not help everyone - if you run it continiously with low pressure, you ll slip and burn your cluthes and no filter will recover it!
Old Dec 7, 2008 | 07:47 PM
celynka's Avatar
Sundance Gold in
Filter replacement its not as easy as an oil filter! One of the brackets needs to be removed, battery to. Atf line is a plug in form one side, and filter has about 1 inch nut on the top of it. It can be done in an hour
Old Dec 7, 2008 | 08:01 PM
I'm definitely gonna look into replacing this filter once I get some free time.
Old Dec 7, 2008 | 08:08 PM
sigh... bring it on killjoy...
Old Dec 8, 2008 | 12:52 AM
bought my car at 40K miles
40K changed trans fluid first time
7K later fluid changed the second time
16K later fluid changed third time
23K later fluid changed fourth time
71K Trans changed out........
each time the fluid was changed it shifted nicely for about 2K miles and I was right back to lumpy shifts....finally the car tossed a P1709 and transmission was replaced......along with them there engine and trans mounts
Old Dec 8, 2008 | 03:26 PM
celynka's Avatar
Sundance Gold in
Yeah! we all agree.... but still... we are talking here about filter change...
Old Dec 24, 2008 | 01:27 AM
2K1CLtypeS's Avatar
Celynka
FYI- no need to remove battery. Was able to change the filter with room to spare....
2k1cltypes
Old Dec 27, 2008 | 08:33 PM
celynka's Avatar
Sundance Gold in
Thumbs up
Originally Posted by 2K1CLtypeS
Celynka
2k1cltypes
Possible, I did not have my car at front of me when I wrote it, however I had my batt out bc i took out every external valve body and cleaned little mesh screens. Great thing that you have done it! It will definately extend life of your tranny . Besides that, you are an evidence that such filter exists and its servicable, so i guess we can close this subject.
Old Dec 27, 2008 | 08:44 PM
you know that filter you are talking only filters fluid going to the differential, right?
Old Dec 28, 2008 | 02:03 PM
celynka's Avatar
Sundance Gold in
No! Fluid is sucked from differential and pumped directly into, oil cooler/warmer and than transmission. Look into schematics 1. pump 2. filter 3 coler /warmer 4. transmission , thats how it goes. Differential shares oil with tranny! Tatz all folks!
Old Jan 3, 2009 | 02:42 PM
lol OK...that's why it is explained in the 2nd gen TL thread that it only filters fluid going to the diff......
Old Jan 10, 2009 | 11:33 AM
Well, the original problem is still there. In SS mode, sometimes still doesn't wanna go from 2 to 3 unless i tap it forward a couple times. Is there some sort of solenoid or something that can be replaced? What electronics are working with these transmissions?
iesu3423
Sep 29, 2015 08:04 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
HeloDown
Sep 8, 2015 06:51 PM
jordanboi
Sep 5, 2015 01:33 AM
