03 cls pull
Old Oct 9, 2012 | 09:16 AM
nc03cls's Avatar
03 cls pull
I have an 03 cls six speed. Brand new tires on are on it and fresh alignment, but the car still wants to pull to the right. It pulls whether the clutch is in or out, and on and off acceleration. It does do it noticeably more under acceleration. Has anyone else had this issue? I'm going to rotate the new tire to the rear to see if it's a tire pull but I can't seem to figure out what else would cause this.
Old Oct 9, 2012 | 04:59 PM
JDM CLS6's Avatar
Im actually having same problems but I know I need an alignment. Let us know if the rotation fixes it.
Old Oct 9, 2012 | 05:16 PM
TLer trash's Avatar
Try crossing them side to side. The result will be more noticeable if it is a tire problem. Also, tires can "push" as well as "pull" so the problem tire may be the left tire. Even if they are directional, you can do this temporarily. Also try driving in the left lane as well as the right. If the car pulls equally left in the left lane, it would be considered normal.
A normal alignment on these does not include camber or caster unless you have installed aftermarket adjustable ball joints or control arms. Toe is the only adjustable angle without aftermarket parts, and it typically won't affect pulling.
Old Oct 12, 2012 | 08:30 AM
Xcivicb's Avatar
Learning New Ways!
I actually have the same problem, mine is also a 03 CL-S6.
I'm getting new tires for the rear soon, so I will get it aligned to see whats going on.
08KBP_VA
Oct 22, 2019 01:55 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
Skirmich
Oct 1, 2015 12:59 PM
h22lude
Sep 27, 2015 06:22 PM
