03 cls manual ecu needed
Old Jan 12, 2013 | 01:34 PM
S2000blur's Avatar
8th Gear
alright after several days of spending hundreds of dollars on new crank sensors i figured out that i will be in need of a new ecu/pcm with that being said i would like to 100% clarify that it is the ecu/pcm i am in search for someone to let me use theirs to make sure of the problem or if someone has a known good one for sale that theyd let me check everything before buying it that would be awesome
Old Jan 12, 2013 | 06:24 PM
S2000blur's Avatar
8th Gear
Can a noob not get any love????
Old Jan 15, 2013 | 10:07 AM
S2000blur's Avatar
8th Gear
seriously no help??? ive gotten more help off of hondatech whitch is know for not helping people i definetly expected a little more support from this group
Old Jan 15, 2013 | 03:24 PM
Search the website below for 'Engine Computer'. A result for Canada and California should come up.
http://www.car-part.com/
Old Jan 15, 2013 | 08:19 PM
AznWay's Avatar
If your looking for ECU here one in AZ BM for sale:
https://acurazine.com/forums/car-parts-sale-361/2g-cl-tl-parts-6speed-ecu-tsx-steering-wheel-rl-caliper-k-n-875866/
If you need local help try using Region Forums:
https://acurazine.com/forums/regional-forums-307/
BTW:
you cannot just swap ECU an just try it. You would needed the key to be problem first to ECU. It will crank but not start.
Good Luck
Old Jan 23, 2013 | 08:50 AM
S2000blur's Avatar
8th Gear
I would just have to swap out the imobilizer correct?
Old Jan 25, 2013 | 09:34 AM
eblanco718's Avatar
3rd Gear
what codes are you getting ?
Old Jan 27, 2013 | 11:07 PM
S2000blur's Avatar
8th Gear
P0335 p0338 and ive replaced both sensors A buddy of mine recently printed of an ecu test off of all data and showed the ecu was bad
Old Feb 20, 2013 | 08:05 AM
S2000blur's Avatar
8th Gear
no longer need an ecu i purchased one and it was not the issue what a pricey way to learn :/
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
cycdaniel
Dec 17, 2019 10:58 AM
tonio
Feb 5, 2019 05:43 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
Tsov Tom
Sep 6, 2015 07:56 AM
