01 CL-S engine cuts out while driving at 5000rpm
Old May 24, 2012 | 01:27 AM
mattrich67's Avatar
7th Gear
Hey everyone. im new to acuras and also new to this page and everything i have googled has brought me to this site and i see you guys know alot.
So i just purchased a 01 Acura CL-S automatic with a 105k miles black on black. it runs great shifts smooth no surgung or anything until i jump on it and it kicks down a gear or two and gets to 5000 RPM and then it starts to rev like a civic reving on his rev limiter. and it also wont shift until i let up off the throttle. it does it all gears i noticed (well besides fourth and fifth i havent gone that fast yet) it doesnt rev up like its slipping it just stays at around 5000-5500
i have no CEL light on and no codes pending that my scanner showed. no lights on on the dash. i did notice that the traction control light flashes when this happens and then goes off.
Also my cruise doesnt work??
The only thing that makes sense to me is if for some reason it thinks it is in neutrual or park and it wont let it pass the rev limiter??
thanks in advance for any help.
Old May 24, 2012 | 03:25 AM
FwC's Avatar
FwC
IDK if this is it, but for cruise control to work, the button left of the steering wheel on the dash needs to be pressed with a green light on it indicating that you can use CC.
My VSA was disabled when I bought the car so I don't know much about it. You should read the FAQ section on VSA and this might give you an answer.
Old May 24, 2012 | 03:57 AM
mattrich67's Avatar
7th Gear
The light on the CC button lights up but I get nothing on the dash? I know this would happen to of the computer doesn't think it's in drive. Or am I wrong?
I will look up on that. Thanks.
Old May 24, 2012 | 08:55 AM
azeezp13's Avatar
shifting at 7k
This is happening to my 6MT as well. The fuel cutoff is at 5 rpm and there is a significant power loss after 3 rpm and you can hear that vtec groan kick in at 3.
Someone help us please.
Old May 24, 2012 | 09:03 AM
have you guys checked your oil level?
vtec is dependent on oil.
also, isnt there a vtec solenoid for you guise?
Old May 24, 2012 | 11:48 AM
mattrich67's Avatar
7th Gear
Has fresh oil change per guy I bought it from. Looks clean and it full
Old May 24, 2012 | 03:10 PM
mattrich67's Avatar
7th Gear
I took the car to the transmission shop and the guy test drove the car and said its not the transmission. He said possibly the rev limiter is bad? Is the limiter in the ECM or??
This car runs and shifts perfect. It only acts up when trying to drive faster then 5000 rpm in all gears. Then it feels like when u rev it in park and it bounces rpm at 5k rpm ???
Old May 24, 2012 | 03:13 PM
mattrich67's Avatar
7th Gear
So while I was driving I had my scanner hooked up and a code popped up
P0034 turbocharger / supercharger bypass valve circuit low and it was current
My car doesn't have a turbo on it? That I know of HAHAHA
Old May 24, 2012 | 03:27 PM
^vtec solenoid.
Also you said "it looks full"
PHYSICALLY CHECK TO SEE IF ITS NOT LOW.
Old May 24, 2012 | 06:51 PM
mattrich67's Avatar
7th Gear
I said its clean and IT'S FULL. How would a vtec solenoid cause it to not rev past 5000 rpms?? That doesn't make sense.
Old May 25, 2012 | 01:54 AM
mattrich67's Avatar
7th Gear
Wow u guys are a great help thanks
Old May 25, 2012 | 07:47 AM
well, when I search to see if any one else has this same problem, LOTS of threads come up.
Old May 26, 2012 | 12:33 PM
civicdrivr's Avatar
Your ECU is in safe mode. VTEC doesnt engage at 3k rpms, it engages around 4500rpm. It most likely is the VTEC solenoid, as noted earlier.
Old May 29, 2012 | 06:15 PM
aznboi2424's Avatar
Yup, safe mode won't let the engine rev up.
Morgan, VTEC engages at 4800 for the Type S and 4400 for the CL-P.
Old May 29, 2012 | 11:16 PM
Dspr_02's Avatar
4800 is a pain on the CL-s, with all the cops around, I can hardly hit VTEC without breaking the speed limit 1 1/2 times over
On a serious note, is there any way to get out of safe mode? (asking for learning purposes...my ECU is fine)
Old May 30, 2012 | 12:43 AM
civicdrivr's Avatar
Fix whatever the issue may be.
Im curious if OPs issue may be related to the range switch
Old May 31, 2012 | 04:05 PM
aznboi2424's Avatar
The engine is in safe mode for a reason, to prevent damage to the engine.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
HeloDown
Sep 8, 2015 06:51 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Desert Ridge
Sep 5, 2015 09:47 AM
