01 Cl factory alarm help???
Hello everyone,
Just got a 01 cl and need factory alarm help.
I searched threads the past 2 days but nothing.
1) when i lock doors with remote the parking light do not blink and siren does not chirp and the security light on driver door does not come on i have even pressed lock numerous times, but when i unlock the doors with remote the parking lights blink twice. any advise or sugestions??
Thanks so much
Pete
Thanks so much
Pete
Hello everyone,
Thanks so much
Pete
Thanks so much
Pete
Received 1,080 Likes
Many times it just requires removing the plug from the hood latch and spraying some CRC cleaner on the contacts.
Hello everyone,
Thanks so much
Pete
Thanks so much
Pete
I have the Python 1400XP
Hi guys thanks for the replys, i can lock and unlock the car with the remote but alarm does not arm, i keep seeing post about hood contact i can not find one anywhere.
how do you know alarm isn't arming? If you can lock the doors the alarm should arm with an extra chirp from the remote if its the factory remote. Also when u lock the doors does the red light flash next to the lock on the driver's side? That means alram has been armed...
Thanks Bonez 21, it locks and unlocks the red light on door does not come on, also i have opened the door after arming it i opened the passengr door an alarm does no go off. (my daugtet has a 99 honda and when i arm her alarm and manualy open pasenger dor the alar goes right off.)
Blackbird baby..
bringing out the dead here.. this is exactly what just started happening on my 03-CLS. The first time, the car was just sitting in the parking lot and the alarm started going off. No nearby cars/people/wind/etc.
WID: Disconnected the wiring connector (2 wire) which is located underneath the front rail right above the hood latch. Word of caution: you'll need to take off the plastic dealy-hoo which blocks access to this. Once you remove that piece you'll have access to the latch. I was able to disconnect the wire without removing the latch from the chassis (4 bolts), but YMMV.
I have [temporarily] disconnected the wire and plan to replace the latch assy asap. For now, the operation is back to normal; alarm arms & flashes parking lights once when locking through the key fob. flashes twice when unlocking. Previously, the arming light flash stopped working--assumably because the front hood latch switch was failed.
I'll try and take/post pics when I get to the repair.
