StreetKA's CLS6 Thread
#761
Whats up with RDX owners?
Yea, its been saying that since Friday. I hope if it does rain, its in the morning and clears up by the evening. Even better - I hope it doesnt rain at all
#765
Shouldn't do that. Fuel Pressure should hit close to 100psi at WOT. Your idle is fine. Was the fuel pump also replaced/new like the rest of the kit? Also did you put in new plugs? Solder the connections on the ESM?
#771
should i disconnect IMRC with Low boost pulley ?
http://www.youtube.com/watch?v=SqLc6YhZyG4
i will try swap wired from ESM it might be that
#773
Maybe you have a leak, I had experienced the same problem with jumping idle from 1-1.5k rpm. Did you replace the gasket where the TB used to connect to the manifold? Mine was beat down/worn out, spray that area with some water where the elbow connects to the manifold. If that's the case, scrape off the gasket really clean and put on a new one.
#774
3.5 psi
^ i just did a search and read that thread JBlue. I also read an old Scalbert post where he accidentally switched the TPS and MAF sensors when doing the install and he had similar idling issues.
StreetKA (09-19-2011)
#779
I cant wait to check it out Wednesday!!
#780
3rd gear pull... i think i need to lower a Fuel pressure is a bit too rich.
http://www.youtube.com/watch?v=zF7B5jU7L40
Dont mind the dirt and iphone quality pic
#783
no i started with low boost to see how clutch will handle it and clutch is perfectly fine i wish i had some energy left to swap the pulley
biggest problem through entire install was removing pulley from alternator, luckily i had one spare alternator without pulley... it took me and my friend alot of beers and cigarets to finish it but it was worth it... install took me about 5h if i dont count in the issues that we run into... it wasnt that hard
#784
Not bad at all.
#793
i hope so :P i have to alternator i think i will use the other one and put HBP on it and this one will have LBP so i will have ability to switch them around easily
is this sound what you're talking about ?
http://www.youtube.com/watch?v=teE-mz780cw
i was expecting boost to kill the sound of the exhaust but now its even louder
http://www.youtube.com/watch?v=Qudro6Q20-Y
#794
Just watched the video. The blower is LOUD.
#798
