2G CL Frequently Asked Questions No New Threads Please.
Bose Stereo Volume knob fix
Old 07-28-2007, 11:55 AM
9th Gear
sweetacura21's Avatar
Bose Stereo Problem...
My volume knob for my 01 cls is all effed up. when i turn the dial it randomly turns the music up or down. anybody know any easy fixes without paying big bucks?
Old 07-28-2007, 03:25 PM
djarovsky's Avatar
My 01 CL-S has that issue from time to time......so I use the steering wheel controls instead. I just live with it. Probably an issue with the knob position encoder. You would have to take the unit apart to fix it.
I have found that if you jiggle the knob sideways with the car off, sometimes it makes things better.
Let us know if you find a fix.
Old 08-20-2007, 03:32 AM
5th Gear
parker's Avatar
Talking im havin the sam problem
hav u found anything out about this problem cus my stereos volume nob is speratic and it takes 4 eva to turn it up if u could help it wuld b much appreciated thanks
Old 08-20-2007, 03:34 AM
5th Gear
parker's Avatar
i jus bought my car so if any of u guys got a tip on how to get the temp gauge to start to work again thanks
Old 08-20-2007, 03:54 AM
Moderator Alumnus
BigLizard's Avatar
It's a wiring problem, I am pretty sure there is a TSB on it.
Old 08-24-2007, 08:03 PM
djarovsky's Avatar
There was a TSB for the steering wheel audio controls.....not the audio unit volume control.
http://www.in.honda.com/Rjanisis/pubs/SB/B03-015.PDF
Old 08-25-2007, 03:46 AM
Moderator Alumnus
BigLizard's Avatar
Yeah but it kind of goes hand in hand. He should look into fixing the audio controls on the steering wheel so he can look somewhere else.
If all else fails it could be teh in dash unit itself.
Old 08-25-2007, 01:52 PM
djarovsky's Avatar
Who said he had an issue with the steering wheel volume control? He stated an issue with the knob on the unit.
The issue is with the encoder on the knob.
Old 08-28-2007, 04:57 PM
Moderator Alumnus
BigLizard's Avatar
http://www.carstereohelp.com/acura.h...RSELF%20REPAIR
Found the fix.
Case solved.
The following 5 users liked this post by BigLizard:
clswhite (10-09-2012), metalheart80s (02-28-2014), Oakroadsteve (01-26-2012), Stephen Jackson (11-03-2013), Stephen00TL (11-01-2015)
Old 08-29-2007, 08:05 PM
9th Gear
Thanks for the link BigLizard... I'll try that out and post whether it works or not.
Old 08-29-2007, 08:56 PM
Moderator Alumnus
BigLizard's Avatar
When I had my OEM unit, it was really bad. Did the cleaning behind the knob fix and it worked.
Old 08-29-2007, 09:19 PM
djarovsky's Avatar
Sweet find....thanks BigLizard!
Old 09-02-2007, 12:12 PM
Registered Type-S Owner
congo's Avatar
lol~ i'm having the same issue, must try the fix, thanks BigLizard!!!
Old 11-25-2009, 01:02 PM
bojangling's Avatar
Same issue. Great fix find, this has been bothering me for years.
Found this at Radio Shack:
http://www.radioshack.com/product/in...ductId=2103700
Anyone know of an (smaller) alternative? Seems like a waste of a large bottle I have no other use for...
Old 04-26-2011, 11:42 AM
Chona's Avatar
I had that problem, I it worked well when I would rase the volume at a slow paste, but when I would rasise it at a fast past it would ether lower or raise the volume, the steering wheen controls worked well tho, I just bought an after market sterio instead since i was going to add a woffer and wanted an aux jack, but i did lose the steering wheel control "/ i here you can add the control again but i was going to cost around 80-100$$$
Old 10-09-2012, 12:27 AM
clswhite's Avatar
Bose volume control failed
Got the Radio Shack Tuner / Contact cleaner; removed the volume knob; sprayed; and it worked like a champ. Thanks BigLizard!
Old 03-14-2013, 10:50 PM
7th Gear
Njr7988's Avatar
Yeah same here. Just use the steering wheel.
Old 08-27-2013, 03:13 AM
frank15p's Avatar
Just used radioshacks contact cleaner and volume knob like new! Thanks!
Old 12-23-2013, 10:19 AM
Lazerburn's Avatar
Worked like a charm. (a charm that works that is...some charms don't work at all and you get your hopes up and lose sleep then nothing.)
oops. does anyone else hear voices?
thnx again.
Old 06-10-2014, 09:51 PM
KR3J//'s Avatar
Worked well, thanks.
Old 04-24-2018, 03:59 PM
Skillz89's Avatar
Bose radio fix
I hate to bring up this old one but I'd rather do that than create a new one.
Does anyone know if this works for controls on steering wheel? Having issues where radio works intermittently and cruise control rarely works.
Old 04-24-2018, 04:04 PM
bkrupp's Avatar
The steering wheel controls are a different and well known issue. The ground ring around the steering shaft behind the wheel looses/has poor contact. There is a TSB fix, or some people just replace the ring.
Old 02-12-2019, 01:25 AM
TxRenee
TxRenee2017's Avatar
Talking Hate to ask..
Thank you BigLizard, I can't wait to try your fix. I'm sure you have solved the first half of my 2003 TL stereo volumn issues. Hitting the store later this morning. Then I'm back forward the fix for my steering wheel control's same issue. Thanks again and have a blessed week.
Warmly, TxRenee
Old 03-02-2019, 04:58 PM
TxRenee
Worked like a
Charm!! Thank you so very much.
​​​​​​Warmly, TxRenee
CL-S progression 01
01-26-2016 04:15 PM
Popee
12-20-2015 12:08 AM
Matthew Purpura
09-25-2015 06:10 PM
Hines57
09-24-2015 01:58 PM
4drviper
09-23-2015 09:00 PM
Quick Reply: Bose Stereo Volume knob fix
