Bose Stereo Volume knob fix
Bose Stereo Problem...
My volume knob for my 01 cls is all effed up. when i turn the dial it randomly turns the music up or down. anybody know any easy fixes without paying big bucks?
My 01 CL-S has that issue from time to time......so I use the steering wheel controls instead. I just live with it. Probably an issue with the knob position encoder. You would have to take the unit apart to fix it.
I have found that if you jiggle the knob sideways with the car off, sometimes it makes things better.
Let us know if you find a fix.
im havin the sam problem
Moderator Alumnus
Originally Posted by BigLizard
It's a wiring problem, I am pretty sure there is a TSB on it.
http://www.in.honda.com/Rjanisis/pubs/SB/B03-015.PDF
Moderator Alumnus
Originally Posted by djarovsky
There was a TSB for the steering wheel audio controls.....not the audio unit volume control.
If all else fails it could be teh in dash unit itself.
Yeah but it kind of goes hand in hand. He should look into fixing the audio controls on the steering wheel so he can look somewhere else.
The issue is with the encoder on the knob.
The following 5 users liked this post by BigLizard:
clswhite (10-09-2012),
metalheart80s (02-28-2014),
Oakroadsteve (01-26-2012),
Stephen Jackson (11-03-2013),
Stephen00TL (11-01-2015)
Moderator Alumnus
Thanks for the link BigLizard... I'll try that out and post whether it works or not.
Same issue. Great fix find, this has been bothering me for years.
Found this at Radio Shack:
http://www.radioshack.com/product/in...ductId=2103700
Anyone know of an (smaller) alternative? Seems like a waste of a large bottle I have no other use for...
I had that problem, I it worked well when I would rase the volume at a slow paste, but when I would rasise it at a fast past it would ether lower or raise the volume, the steering wheen controls worked well tho, I just bought an after market sterio instead since i was going to add a woffer and wanted an aux jack, but i did lose the steering wheel control "/ i here you can add the control again but i was going to cost around 80-100$$$
Worked like a charm. (a charm that works that is...some charms don't work at all and you get your hopes up and lose sleep then nothing.)
oops. does anyone else hear voices?
thnx again.
thnx again.
Bose radio fix
I hate to bring up this old one but I'd rather do that than create a new one.
Does anyone know if this works for controls on steering wheel? Having issues where radio works intermittently and cruise control rarely works.
The steering wheel controls are a different and well known issue. The ground ring around the steering shaft behind the wheel looses/has poor contact. There is a TSB fix, or some people just replace the ring.
TxRenee
1 Post
Hate to ask..
Thank you BigLizard, I can't wait to try your fix. I'm sure you have solved the first half of my 2003 TL stereo volumn issues. Hitting the store later this morning. Then I'm back forward the fix for my steering wheel control's same issue. Thanks again and have a blessed week.
Warmly, TxRenee
Warmly, TxRenee
Hines57
09-24-2015 01:58 PM
4drviper
09-23-2015 09:00 PM
