2G CL Frequently Asked Questions No New Threads Please.
3.5 liter hybrid build information
Old 12-22-2009, 09:21 PM
  #41
acura_honda_30cl's Avatar
Ok i guess u 2gen guys could answer dis question..i want to know what bolt on internals i could put in my j30 to turn it to 3.2...and can i change my IM to a 3.2 intake manifold would it bolt up with no problem...so what crank and piston etc. I need to use..one thing can the 3.2 TB bolt up on the j30 as well?.....1gen people cant answer so i went to u guys...
Old 12-22-2009, 09:35 PM
  #42
B A N N E D
friesm2000's Avatar
i would think every thing should basically bolt right in, only thing i might say would be is the distribuater, but none of the parts relate to that, so should be no problems with it (other then maybe clearence issues around the distribuater with the intake, but i don't think it will)
anyway's you can buy CIVICDRIVER'S old parts, proably for dirt cheap too
Old 12-22-2009, 09:39 PM
  #43
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,182 Likes on 4,827 Posts
*ahem* civicdrivr
Nope, don't have 'em. Only thing I still have is the clutch setup.
Old 12-22-2009, 09:48 PM
  #44
B A N N E D
friesm2000's Avatar
*ahem* civicdrivr
o-well i must have accidently hit an extra E ,
so what happened to your stock parts then, did the shop not give them back to you??? (and don't you still have your stock manifold though, that is't suppose to be up in the attic or something, [that you were suppose to get measurements from :shakehead])
Old 12-22-2009, 10:39 PM
  #45
civicdrivr's Avatar
The cams, two broken rockers, old pistons, rods and crank were so worn it didnt make sense for me to take them. I was offered them though.
And yea, I still have the manifold, but its cold in my attic :ghey:
Old 12-23-2009, 01:24 AM
  #46
so u guys trying to say i could use the j32 IM and TB? what about the heads, crank and the other goody's, that will turn my j30 to a j32...
Old 01-03-2010, 06:37 PM
  #47
stevenusmc's Avatar
would my headers and pulley bolt on to a j35 block
Old 01-03-2010, 06:41 PM
  #48
B A N N E D
friesm2000's Avatar
what series of block (what is the engine code on it; what vehicle it is from would help too)
Old 01-03-2010, 07:06 PM
  #49
stevenusmc's Avatar
i have a j32/a2 02 acura tl-s trying to get the best n/a setup dont want to loose my current mods
Old 01-13-2010, 05:28 PM
  #50
2N10s's Avatar
i got the same qusetion as well... i got a J35A4 (2003 odyessy block)
Old 01-13-2010, 05:38 PM
  #51
3.5 psi
gnuts's Avatar
as far as i know the blocks are indistinguishable/interchangeable -- the ones listed in the oringinal post. I know people who have done the 3.5 still use their underdrive pulley. I don't see why headers wouldn't go right back on.
Old 04-17-2010, 03:36 PM
  #52
fu
Slepybear's Avatar
I tried reading through this, but I was kind of confused, so maybe someone can just answer this question for me..
If I were to do a CL-s engine/tranny swap into my 2g tl-p, would that all bolt in pretty easily?
And then before I put in the CL-s engine, if I were to build the engine into a 3.5L, would that be possible? Through the rl pistons or whatever it is exactly that I'd need..
So then I would have a 3.5l CL-s engine, that is the final result I want. Or 3.7L if that is possible.
Old 04-17-2010, 04:16 PM
  #53
3.5 psi
gnuts's Avatar
remember the TL-S and CL-S engine are the same.
It would be really easy if you were to stay auto. 01-02 MDX or 02-04 oddy bottom end with TL-S/CL-S heads.
Old 04-17-2010, 04:28 PM
  #54
civicdrivr's Avatar
The S motor will bolt in, but not wire up.
Old 04-20-2010, 03:39 PM
  #55
fu
Slepybear's Avatar
Well what I want to do is a 6spd swap from a cl-s, then also swap the engine to a cl-s at the same time. I noticed in the swaps were just the tranny is swapped or a tl engine is used, it takes a lot of modification to make it run with the manual tranny.
So I guess what I am really asking is that if I were to buy a CL-s engine and tranny, those would bolt in?
And then if I wanted to change it to a 3.5l I would then have to use the bottom end of an RL or Oddy engine?
What I want to do this summer is buy the CL-s engine and transmission I found, convert the engine to a 3.5l, and then put in all my bolt-ons, then install that. Is that possible?
Even if the ecu is swapped and I buy the wire harness? What else would it take to make it all wired up correctly?
Old 04-20-2010, 04:44 PM
  #56
3.5 psi
gnuts's Avatar
you'll have to take a look at this first if you haven't already:
https://acurazine.com/forums/2g-tl-1999-2003-98/6-speed-conversion-591872/
You would basically do exactly what's in that thread but put different crankshaft, rods and pistons in. I don't know if it would be cheaper to just buy the internals and put those in or buy a whole Oddy/MDX short block and just change the pistons.
I don't think your headers will bolt on unless they have the bend in the rear meant for the 6speeds. Everything else should be fine.
Old 04-29-2010, 12:54 PM
  #57
nf3d0149ab's Avatar
Great thread...a lot of the information I'm looking for!
Thanks for this info!!!
Old 07-11-2010, 09:50 AM
  #58
Like a BOSS
Ep3moschini's Avatar
I have an 01' TL-P can I just swap an Oddysey motor into my car and run with it? maybe toss some RL pistons in the mix for fun
Old 08-29-2010, 09:50 AM
  #59
type r teggy's Avatar
question
Hi im kind of new to this site. i just bought a 03 cl type s 6 speed. i want to make y car a 3.5 liter with the mdx crankshaft and piston rods. If I use Rl pistons will I be able to use my stock computer? I understand I will have .5 more compression with the rl pistons. WHat if i use the cl-s pistons? also non of this will throw off the balance of the rotating assembly so i can use the stock flywheel and all that from my stock type s correct? i have a spare j32a2 and an mdx block. I just want to be sure before i put it together. Any help would be appreciated
Old 08-29-2010, 02:50 PM
  #60
3.5 psi
gnuts's Avatar
your CL ecu will be fine. May want an adjustable fuel pressure regulator. Use the MDX crank and rods. For pistons you can use your CL pistons for lower compression of RL pistons. RL pistons will yeild slightly more power. Everything else stays the same.
Old 08-31-2010, 02:49 PM
  #61
niceeee i appreciate the help. i want all the power i can get so i can use th rl pistons with the stock computer also? I work for a machine shop and i can port and polish my heads and inake manifold for free. is it worth it? how much power will i gain if i port the both?
Old 08-31-2010, 03:47 PM
  #62
3.5 psi
gnuts's Avatar
yes the stock CL ecu can handle the 3.5 upgrade...many have done it. Like i said the FPR will help to keep your air/fuel where u want it. Definitely port your intake manifold and runners. Once you stroke the motor it begs for more air. If you really want a crazy intake manifold, talk to NVA-AV6. He is a builder in VA and he has made an intake manifold for a guy here with a 80mm throttle body. here's his link:https://acurazine.com/forums/2g-cl-photograph-gallery-53/my-build-thread-bordering-more-bs-56k-beware-769245/
Old 10-20-2010, 08:20 PM
  #63
StreetKA's Avatar
i got 04 ody engine all i need is CL/TL Type S heads and CL or RL pistons ? but what i get CL-S heads from auto ? i know that there is probably diff between CL auto/manual heads. im asking that bc i want to build the engine first and then swap it over and also i want to do TB service on that motor as well.
Old 10-21-2010, 07:06 AM
  #64
3.5 psi
gnuts's Avatar
nice! i think it would be cheaper for you to use what you already have from your motor. And yes i believe the auto is different.
Have a shop complete the bottom end on the oddy engine - new pistons/rings, hone, new bearings on the crank - then drive your car in and have them pull the engine and swap your heads over, reinstall. That'll save you from searching for and buying new heads. Then you can sell your complete CL block for some $ back. You shouldn't be without your car for more then a day or two.
Old 10-21-2010, 07:30 AM
  #65
StreetKA's Avatar
Im sure it would be cheaper but i want to do motor myself with help of my friend mechanic. So it would be nice to have spare cl-s head so ican make sure that everything is gonna be ready and tb service done as well. Then i would go to shop to swap it over. That would save me alot of money. But still i need those heads.
Old 10-21-2010, 08:11 AM
  #66
3.5 psi
gnuts's Avatar
i see. might have to just keep an eye out on carpart.com for some 6speed heads. I've been dying to do a big power mod, but the family is growing now...might have to put it on hold.
Old 10-21-2010, 09:15 AM
  #67
B A N N E D
friesm2000's Avatar
, did't you just get married like 2-3 months ago
Old 10-21-2010, 10:20 AM
  #68
3.5 psi
gnuts's Avatar
yup! I work fast! lol. We've known each other since kindergarden, so the wedding was a formality.
Old 10-22-2010, 10:53 AM
  #69
3.7L Nitrous Breathing CL
richardparker's Avatar
And it also would not hurt having the heads before the swap.
That way you could replace valve seals,give a quick lap to the valves,and atleast gasket match the heads.
Old 10-22-2010, 09:22 PM
  #70
StreetKA's Avatar
what is in my head is to use '10 TL IM get it ported and polished... j35a4 bottom j32a2 heads and RL pistons... is it j35 then or j36 ? hehe thats a real hybrid and full junkyard under the hood :P
Old 10-22-2010, 10:18 PM
  #71
3.5 psi
gnuts's Avatar
that's a J35 (3.5L). J36 (3.6L) is a J37 crank i believe. Also i don't think you can port the 09+TL manifold because it's magnesium. The reason it's better is because of the material and it already has larger runners.
Old 10-22-2010, 10:25 PM
  #72
B A N N E D
friesm2000's Avatar
not so much that, but more the fact that from the factory it was designed to not have any excess material, so if you do attempt to port it, you will severely compromise the wall's integrity, with them getting too thin
Old 11-28-2010, 12:26 PM
  #73
wait a secc. What is the difference between cl-s 6 speed heads and tl-s auto heads? I have all the parts and im ready to build my engine. I have a cl 6 speed and a spare tl-s auto engine and was planing on just builing the auto engine and swapping it into my cl?
Old 11-28-2010, 07:02 PM
  #74
3.5 psi
gnuts's Avatar
Originally Posted by nspec_ya4
6 speeds have different front cam gear and sensor and the back plate, also have different crank gear and sensor.
The autos have another sensor coming out of the front head, from behind the cam gear plate.
if you're staying auto then just stay with the auto engine. why no manual?? added power with a crappy auto tranny ...???
Old 11-29-2010, 01:08 AM
  #75
What im saying is that I have a 03 cl 6 speed Car. I have a spare engine from a 02 tl type s and i wanted to do the 3.5 conversion to that engine so my car wouldnt be off the road. SO are the Engines not compatible? or can i do my build to the Tl engine and use whatever parts from the 6 speed to make it work?
Old 11-29-2010, 05:32 AM
  #76
StreetKA's Avatar
You can use TL S motor but you have to swap the cam and gear sensor and gear from manual head. Or just simply reuse manual heads. But thats all. You can reuse block it has iron sleeves and pistons but i would go with RL ones. All you really need to build spare motor is heads bottom from odyssey or mdx on the first page you have all the info you need. If you want save money you should reuse CL pistons but the have different compression than rl ones iirc that makes you able to run regular gas if you want.
Old 11-29-2010, 07:15 AM
  #77
ok cool its a good thing i can use at least the castings of the heads because i ported them at my job as i work for a machine shop. Heres another questions......What is the difference between intake manifold and thottle body on the automatic and the manual?. I really appreciate this help.
Old 11-29-2010, 08:30 AM
  #78
StreetKA's Avatar
Im sure that IM is the same but TB is different because auto has VSA. But you can make it work.
Old 11-29-2010, 01:51 PM
  #79
civicdrivr's Avatar
VSA isnt part of the throttle body on the autos, its what many people mistake as the "second" throttle body. You just remove it and the TB and intake are the same.
Old 11-29-2010, 02:05 PM
  #80
StreetKA's Avatar
My info was based on what i've learned reading on tgis forum since i do not have auto i didnt know how does it looks like. I thought in auto TB and VSA is one piece my bad.
Quick Reply: 3.5 liter hybrid build information
