CL-S6 CT headers
Old Jun 19, 2011 | 07:06 PM
BAGII's Avatar
CL-S6 CT headers
My CL-S6 dynoed before and after comptech headers.
Before: http://www.youtube.com/watch?v=C0B7ESymGBM
After: http://www.youtube.com/watch?v=mGlsX...eature=related
loving it
Old Jun 19, 2011 | 07:15 PM
CL-Future's Avatar
Lives in Boost
Nice vids and numbers. Can never get tired of that sound...
Old Jun 19, 2011 | 07:16 PM
BAGII's Avatar
Yep! 221 before and 242 after
Old Jun 19, 2011 | 07:26 PM
AARONSredTYPE-S's Avatar
wow, 221whp stock and 242whp with just headers?
dude, is that all the mods you have?
if so, that is a really strong engine. great numbers man
how many miles on it?
what gear did you run the dyno on, 4th?
Old Jun 19, 2011 | 07:36 PM
BAGII's Avatar
This was a 3rd gear pull. The car just rolled over 135,500 and not a leak in sight and I got an AEM CAI, too. That's it
Old Jun 19, 2011 | 07:45 PM
wow, thats awesome.
my car just turned 134k miles, and mine is in wonderful shape too, but i didnt think i would dyno near that at all.
i have intake, headers, spacers, exhaust, neuspeed suspension...ext
i need to go to the dyno and see what i put down, hopefully around 250whp if mine is as healthy as yours...thanks for the vids man
Old Jun 19, 2011 | 08:05 PM
friesm2000's Avatar
B A N N E D
torque seems really low though for the HP for the engine
also i see one MAJOR thing for the different dynos, first one the hood was shut, so heat soak is more then likely dropping those numbers some, compared to the second pull with it open, allowing the heat to escape (so the amount of power you gained is not going to be correct, since the hood being open is the norm usually)
Old Jun 19, 2011 | 08:10 PM
wow, nice catch, but it still shouldnt be that much difference, especially if both runs were in good weather, or at least the same weather conditions
Old Jun 19, 2011 | 08:18 PM
friesm2000's Avatar
B A N N E D
have you ever tried putting your hand on the intake manifold, after you had been sitting in traffic, with the engine fully warmed up? if not, it gets to the point where you can not even touch it for more then a couple of seconds
BUT then if you say try and touch it after like a long highway cruise, it's cool enough that it is just kinda luke warm, and you are able to leave your hand on it all day almost
so yes it could easily make a good 10-15 hp difference, if not more, when the motor gets heat soaked (even if the weather conditions are the exact same)
btw even then that fan they have seems kinda small to start with for trying to get full power when you are just sitting there
also OP, i would be bitching if they had tried to tie my car down like that on the rear, there are tie down points on the chassis, suspensions are REAL EASY to bend/tweak like that (it's better then hooking to the suspension arms themselves though)
Old Jun 19, 2011 | 09:23 PM
BAGII's Avatar
When I dynoed it before the headers, we tried with the hood open and closed and didn't really make a difference. I have other vids on youtube for proof.
Old Jun 19, 2011 | 09:30 PM
friesm2000's Avatar
B A N N E D
between the hood being closed and open, did you allow enough time for everything to cool down, and not be heatsoaked?
Old Jun 19, 2011 | 09:35 PM
BAGII's Avatar
Yeah, everything's legit. The only factoring difference between the vids are the headers.
Old Jun 19, 2011 | 10:57 PM
damn 204wtq is low.
what would cause it to be low i wonder?
anyways, now go run the 1/4 and lets see it on that too...gl
Old Jun 20, 2011 | 03:22 AM
BAGII's Avatar
I don't know what would cause it to be low. I didn't really think it was that low I guess but now that I look at it, I don't know. All I noticed was that my torque curve was much better after the headers and that peak torque went up a little.
Old Jun 20, 2011 | 09:15 AM
yeah your torque went from 194 to 204, but it should have been 204 to begin with and go up to about 214, at least from looking at most on here. The only people i saw with your torque numbers were people that had a bad imrc or needed a valve adjustment. your top end is right where it should be though..
get a 2.5" exhaust and you will feel the full affect of those headers...gl
Old Jun 20, 2011 | 11:42 AM
BAGII's Avatar
Yeah, I know I need a valve adjust and spark plugs. I still have the original NGK's in there. And I figured I would need a valve adjust since I'm at 135k. And I need to get it done before the races on Friday.
Old Jun 20, 2011 | 12:39 PM
inspiron0937's Avatar
nice! damn i need some headers too
Old Jun 20, 2011 | 12:54 PM
YEAH it will make a difference for sure. Also, the engine torque dampers as well, which i am replacing next weekend myself...gl at the track
Old Jun 21, 2011 | 12:05 AM
civicdrivr's Avatar
The numbers seem a bit "off" because you did these runs in third gear.
Old Jun 21, 2011 | 08:46 AM
how do you know it was it 3rd gear?
we are supposed to be in 4th in our cars right?
damn, that means he would be even higher in the right gear..wow
Old Jun 21, 2011 | 05:33 PM
civicdrivr's Avatar
We should be in the gear that is closest to a 1:1 ratio, which is fifth, but everyone dynos their car in fourth. The numbers wont vary much though.
The biggest thing here is both runs were done in third. The numbers themselves dont mean shit, the gains are what matters.
Old Jun 21, 2011 | 07:38 PM
Rejckt's Avatar
Ratios (:1)
Manual
1st gear 3.933
2nd gear 2.478
3rd gear 1.700
4th gear 1.250
5th gear 0.976
6th gear - 0.771
Reverse 4.008
Final Drive Ratio 3.286
Old Jun 21, 2011 | 09:17 PM
looks like 4th..hmm, either way, if he was in 3rd, he was def. not in the right gear for the dyno.
hopefully we can see a 4th and 5th gear dyno to get a reference of the difference
Old Jun 21, 2011 | 11:31 PM
civicdrivr's Avatar
5th is .024 away from 1.000, while 4th is .25 away - 5th is closer.
But as I said, the difference wouldn't be great. His numbers would be slightly higher however.
Old Jun 22, 2011 | 07:33 AM
Yeah, but it would be nice to see the difference
Old Jun 29, 2011 | 10:55 PM
BAGII's Avatar
You guys think I would have higher numbers if I did a 4th gear pull? That would be sweet! Either way took her to the track this weekend. Had a blast! wondering how I can improve 60' time?
Old Jun 30, 2011 | 08:09 AM
What did u run at the track?
Old Jun 30, 2011 | 11:53 AM
BAGII's Avatar
I ran a 15.252 @ 93.25. don't laugh! This is at 4500 ft. elevation. I had an 0.088 reaction time which I'm stoked about but 60' is still in the 2.4's and that decides the whole race.
http://www.youtube.com/watch?v=0P3CLSbL-qQ
A density altitude calculator tells me I would run a 14.113 @ 100.7 at sea level.
http://www.dragtimes.com/da-density-...ect+ET+and+MPH
Old Jun 30, 2011 | 12:04 PM
Not gonna laugh since I've never even been to the track yet But damn how slow is that a4?
Old Jun 30, 2011 | 12:10 PM
BAGII's Avatar
Yeah, my buddy was having a worse time getting out of the whole than I was. He bogged his turbo that time.
Old Jun 30, 2011 | 05:59 PM
damn, altitudes make that much of a difference? 15.2=14.1?
You are running slower than a stock auto would be here in Florida, and its hot as hell down here....lol....gl
Old Jun 30, 2011 | 08:10 PM
BAGII's Avatar
Yeah, its a huge difference with N/A cars. Turboed cars aren't affected as much, though, cause they create their own atmosphere in the intake but they're still affected too.
Old Jul 9, 2011 | 01:33 AM
CH46ESeaKnight's Avatar
Sounds about right. I had a turbo car that was running 14.1 at 5000ft. I got to run it at about 3000 ft and pulled (in hotter temps then the 5000 run) a 13.7.
Nice to see the before and after. Nice job!
Old Aug 3, 2011 | 02:18 AM
BAGII's Avatar
http://www.youtube.com/watch?v=E5CtH..._order&list=UL
Still gotta bring my 60' ft. down. I can't hook up at all.
Old Aug 3, 2011 | 04:28 AM
StreetKA's Avatar
i cant see anything... what was the time?
Old Aug 3, 2011 | 08:18 AM
civicdrivr's Avatar
Cant see the time either but if I go off the video timer it looks like mid 14s.
Old Aug 3, 2011 | 08:48 PM
BAGII's Avatar
it was actually 15.0 @ 94mph, I wish I could get mid 14's here. I need to bring it down to sea level and see how I do to make myself feel better
Old Nov 30, 2011 | 02:15 PM
KnightWKNF's Avatar
Do you have the actual charts when dynoed the before and after headers? Trying to settle a dispute at work.
Old Nov 30, 2011 | 03:38 PM
BAGII's Avatar
Here you go, before and after charts
Old Nov 30, 2011 | 06:14 PM
KnightWKNF's Avatar
Thanks so much!
