wtk
Old Feb 15, 2011 | 11:46 PM
ivan06106's Avatar
wtk
im planning on buying some p2r throttle spacer, gasket, an the intake manifold gasket, but i have seen the outlaw engineering but dont know which one should i go with it, any suggestions
Old Feb 16, 2011 | 02:42 AM
nf3d0149ab's Avatar
Haven't heard of anyone running outlaw engineering.
Old Feb 16, 2011 | 04:36 AM
StreetKA's Avatar
There is actually couple of ppl on website that i heard they are using it
Old Feb 16, 2011 | 06:54 AM
gnuts's Avatar
3.5 psi
i have the outlaw spacer kit new in box at my house. Might not be needing it now. I chose that over the P2R because it's a thermo gasket and a spacer. The intake manifold one is about 1/4" thick and gives a bump in torque (acts like the MDX spacer, just thinner, and no clearence issues) as well as lowers temps. Comes with the throttle body spacer as well and all hardware. They have dyno charts on their site on a TL-S.
Old Feb 16, 2011 | 07:21 AM
nf3d0149ab's Avatar
Oh ok. Sounds good.
Old Feb 16, 2011 | 08:19 AM
fuzzy02CLS's Avatar
I have them. Had them for a few years, before the P2R was on the market.
I didn't notice a difference. Manifold feels just as hot as it did before.
I think the P2R's are a bit thicker then the Outlaw ones though. Might see a better gain. I wasn't investing any more $ or time changing mine to find out.
Old Feb 16, 2011 | 08:56 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i have the p2r ones they are probable 3mm thick or so.. they went one the car last year I think and if i recall correctly they are all the same thickness.
personally i think they are definitely closer to an 1/8 of an inch
Old Feb 16, 2011 | 12:22 PM
ivan06106's Avatar
thanks guys,so do i used the same bolts wen i install the p2r intake manifold gasket
Old Feb 17, 2011 | 01:57 PM
aznboi2424's Avatar
I think they give you extended bolts.
Old Feb 17, 2011 | 03:54 PM
yes u use the same bolt for the manifold gasket.
some people use the oem one and the p2r one. it's really personal preference but I just used the p2r gasket.
for the tb spacer yes new bolts are included. make sure u get 2 gaskets for the spacer as well. that way it's a full inch of volume gained in the intake system (and it helps prevent heat soak of the spacer too)
Old Feb 17, 2011 | 03:56 PM
ivan06106's Avatar
thanks
CHICKEN204
4G TL Photograph Gallery
Feb 8, 2020 07:50 PM
jmscarrion
ILX
Oct 17, 2013 09:04 PM
Nukebug
37
Jul 2, 2013 12:39 PM
ojasdatt
Jun 21, 2012 11:46 AM
