wtk
wtk
im planning on buying some p2r throttle spacer, gasket, an the intake manifold gasket, but i have seen the outlaw engineering but dont know which one should i go with it, any suggestions
3.5 psi
i have the outlaw spacer kit new in box at my house. Might not be needing it now. I chose that over the P2R because it's a thermo gasket and a spacer. The intake manifold one is about 1/4" thick and gives a bump in torque (acts like the MDX spacer, just thinner, and no clearence issues) as well as lowers temps. Comes with the throttle body spacer as well and all hardware. They have dyno charts on their site on a TL-S.
Haven't heard of anyone running outlaw engineering
I didn't notice a difference. Manifold feels just as hot as it did before.
I think the P2R's are a bit thicker then the Outlaw ones though. Might see a better gain. I wasn't investing any more $ or time changing mine to find out.
lowrd on tein CS biatch
yes u use the same bolt for the manifold gasket.
some people use the oem one and the p2r one. it's really personal preference but I just used the p2r gasket.
for the tb spacer yes new bolts are included. make sure u get 2 gaskets for the spacer as well. that way it's a full inch of volume gained in the intake system (and it helps prevent heat soak of the spacer too)
thanks
Nukebug
37
07-02-2013 12:39 PM
