window rolls up reaaallly slow
I wouldnt think it could be an obstruction unless you got hit on the drivers side door recently. It's probably the motor going bad and it shouldnt be too bad a DIY if youre somewhat mechanically inclined lol
I'll try and find the thread I found about how to replace it...
On another question about the window though, I know the window is auto down but is it suppose to be auto up too? Just wondering cuz it seems cars defined as "luxury" should have the auto up feature, unless its a 'newer' idea and came after 2001-2003
Wide Body 3.2 CL-S
Uses turn signals in my
The channeling could be rotting out, spray some WD-40 into the channeling areas (dont forget on the pillar area) and see if that helps. I was recommended to do so by a guy who repairs automotive windows for a living and it worked on my vehicle.
Received 1,080 Likes
Unregistered user
do not spray wd-40, WD40 is petroleum based it was eat rubber!
go to a honda dealer and buy shinetsu 08798-9013 it's a grease just for windows. read on the acura legend board it works WONDERS. any honda dealer will have it since they USE IT A LOT on the cars the service.
more info at: http://www.acura-legend.com/vbulleti...s-read-122158/
but according to http://www.wd40.com/faqs#q8:
What surfaces or materials are OK to use WD-40 on?
WD-40 can be used on just about everything. It is safe for metal, rubber, wood and plastic. WD-40 can be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Unregistered user
Thanks for the extra info, I may look into that in the future.
it does say its petroleum based, but also claims it is safe for rubber. I haven't seen any degrading to the rubber since I have been using it.
wd-40 can't be used on everything, its no miracle spray.
Ty guys
NF3, I'll take the door apart and see if theres anything in the way....
I havent had any accidents since I've had the car, and it used to be fine, so I'm guessing its the motor
I found some on amazon for 80 bucks, not bad. I had the door panel apart about a year ago doing a speaker install, wish I had known then
as far as auto up nope, my IS350 rolls up auto though, its actually a pain in the ass because if you want to just crack it, you have to do it ever so gently.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Restored this in 1998
Whats up with RDX owners?
Ummm, it does. At least mine does. I just wish the passenger side was auto up/down as well.
03. Pull up your switch, do you feel a notch? If so, your auto feature probably isnt programmed correctly. If you disconnected the battery, you'd probably have to program it. Basically, roll the window down all the way and hold the button for 3 seconds, the go all the way up and hold for 3 seconds. Programmed.
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
Thanks guys.
xsilverhawkx
09-28-2015 06:51 PM
