Window Auto Down
Window Auto Down
Does this feature only work when the window is fully up, or should it also work when the window is partially down? Mine doesn't seem to work when the window is partially down now and I can't remember if that is normal or not. Thanks.
do u have an aftermarket alarm with smart windows? Mine is working wierd, it barely ever lets me use auto down. It goes down like 1/5 of the way everytime.. im tryin to see if there is a way i can change that setting or something.
No aftermarket alarm. The auto down seems to work sometimes, but the rest of the time the window goes for a second or two after I release the button, but doesn't make it all the way down.
Above n Beyond
try and resest it. roll your window up, then roll it down. Once its fully down keep holding the button down for a few more seconds. let go and roll your window up. once its up, hold it up for a few more seconds. this will reset your window up/down and maybe that will do the trick. its worth a shot.
sorry for the hijack, but is the auto up and down feature only for the driver's side window or does it work for the passengers as well? Because only the drivers side works for me
Did recently replace my battery over the winter. Not sure if that coincided with the "auto" down feature not working as I rarely used the feature in the winter.
Tried to reset the window, didn't seem to work. From the window all the way up position, i rolled it all the way down and held for a few seconds. Then rolled all the way up and held for a few seconds. Didn't seem to do anything.
Also, the "auto" down feature would work intermittently before, just not reliably. Wouldn't it not work at all if it wasn't "reset"?
