Will these void my warranty
CLS 6 Speed
I'm going to take in my 2003 CL-S to my Acura dealer for the first time because of a check engine light and I was wondering I have an AEM CAI installed as well as H&R Sports Springs will the CAI or the Springs void the car's warranty in any way?
Originally Posted by KahRupt-CL-S03
Try taking the positive terminal off the battery for about 20-30 minutes, this will reset the computer and the light could come off.
Disconnect the negative terminal for 10 minutes.
Doin' da crack shuffle
Negative terminal silly.
'Big Daddy Diggler'
reseting the check engine light will not do anything if you have a problem. But if the car is running fine, reset it. If the light comes back then go to the dealer.
CLS 6 Speed
I have reset it and the light is still on I check the codes using the old paper clip and two codes came up code I think # 65 a secondary oxygen sensor and # 119 Coolant engine temperature circuit malfunction at least that's what I found and neither one has anything to do with the CAI because before I found out what the codes were I took the CAI off and put back the original box reset the Check engine light and it came back on. I would put the original box back on when I take it to the dealer but the thing is I don't have it anymore so I'm stocked with the CAI. 2 cents anyone?
