Will these headers fit
Old Jun 17, 2014 | 10:08 PM
o0o0o0's Avatar
Finally Registered
I just picked up a 2-3 month old set of xs power headers. But when I compare the rear bend to other xs power header it looks smaller. How big does the bend have to be to clear CLS 6 speed rear motor mount?
Here is a pic of what i bought
Old Jun 18, 2014 | 06:35 AM
Scottyknows007's Avatar
The bend in mine was similar, maybe even a little more bent (slightly), and I had to remove the motor mount to install mine.
Let me know how your install goes!
Old Jun 18, 2014 | 07:44 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Iirc the bend in those looks to be a little off.
The header bend is usually a little higher up and more pronounced as the bend occurs over a shorter distance on the comptech headers I have seen.
But that's not to say those will not work. But I think it's going to be very tight
Old Jun 18, 2014 | 05:31 PM
o0o0o0's Avatar
Finally Registered
hopefully they will fit, I won't be installing them until next week
Old Jun 19, 2014 | 01:29 AM
Karanx7's Avatar
Unregistered Member
Exactly like CL-S Progression said, mine was a bigger bend higher up. I installed mine without touching the rear mount, and had plenty of space.
Old Jun 19, 2014 | 01:47 PM
o0o0o0's Avatar
Finally Registered
I noticed the same thing when I saw picture of the headers. I read on a thread of a member grinding the mount down to fit auto headers. looks like he only grinded 5-10mm. I think the bend should clear that. Hopefully I can get them to fit.
Another question what o ring gaskets did you guys use?
Old Jun 19, 2014 | 06:27 PM
03-6/6's Avatar
M90booosted
i used the rings that came with my xs power. so far they are ok. the front flanges arent lined up very well. i had to notch the front subframe so it wouldnt rub.
Old Aug 3, 2014 | 06:27 PM
o0o0o0's Avatar
Finally Registered
Finally installed them and they fit. It was a tight fit. For any one thinking of purchasing headers, I would install it yourself. All I used was a craftmans tool set and a breaker bar and I found the job easy.
Old Aug 3, 2014 | 08:57 PM
Karanx7's Avatar
Unregistered Member
Also, I installed a pair of used headers. Exhaust leaked bad where the collectors joined the j-pipe. Definitely get new gaskets. Sometimes you can't even see the exhaust leak if it's minor.
Old Aug 4, 2014 | 10:23 PM
o0o0o0's Avatar
Finally Registered
I used new o ring gaskets. How can I tell if I have a leak?
Old Aug 5, 2014 | 08:25 AM
gnuts's Avatar
3.5 psi
Really soapy water and a brush. Look for bubbles.
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
ROWDY621
Sep 30, 2015 03:20 PM
Bielikb96
Sep 28, 2015 10:45 AM
