will this hitch fit my car?
Old 01-22-2010, 09:41 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
Will a hidden hitch for an accord 98-02 fit an acura CL??
Old 01-22-2010, 09:52 PM
i may have answered my own question
http://cgi.ebay.ca/97-02-ACURA-CL-99...item414c0e2a69
Old 01-22-2010, 10:05 PM
Blown is Best
Allout's Avatar
Hidden Hitch # 60913 will fit:
2001 - 2003 CL
1999 - 2003 TL
1998 - 2002 Accord
Old 01-22-2010, 10:59 PM
B A N N E D
friesm2000's Avatar
it is actually a "cequent towing products" product, they just slap on a different name, and charge accordingly
still all the same thing, just a different sticker like reese, hidden hitch, draw tite
here are the install instructions:
http://www.hiddenhitch.com/fitguides/pdf/N60913.pdf
no drilling needed
curt hitches also makes a hitch for our cars, but there design looks like crap, let alone being universal design, and having to drill two of the three mounting points out
install instuctions:
http://sitepro12.sitepro.com/masterl..._11290_INS.pdf
don't like how you just drill into the floor pan, at least attach to the frame rails like above ^^^ for stabilization
they also have this design, but i still don't like it:
http://fileresource.sitepro.com/file...97808975B9.pdf
not a fan of making the bumperbeam also doing the work, let alone not much front to back stabalization on it, and drilling again :shakehead
also remember on all 3 designs the rear tow hook is taking the load from the hitch, with the arms just stabilizing the reciever part
why you want a hitch anyways???
Old 01-22-2010, 11:02 PM
for a bike rack cause I am getting back into mountain biking.
so this will be more than sufficient correct?
only weighs 25lbs thank god
Old 01-22-2010, 11:18 PM
B A N N E D
friesm2000's Avatar
rated for 200 lbs weight, so should be more then sufficient
also remember the rack itself weighs some too, and also what happens if someone else goes with you, even more weight back there , but you still be way under the weight limit though so NP there,
just be aware your back end might sag a little bit from the weight being so far back there, so takes bumps and such slow, and you should have no problem
as said i would prefer the cequent hitch over the curt one, but it looks like you have already done that (i prefer no drilling required installs )
Old 01-22-2010, 11:25 PM
well yea the one that's for sale is a hidden hitch so I don't have a choice right?
this is what it looks like... is this gonna stick out and look ugly??? or is this the best one i can get (asthetically speaking)
Old 01-22-2010, 11:28 PM
here is the link... I will have to sand and repaint... but w/e
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ180453299
Old 01-22-2010, 11:37 PM
B A N N E D
friesm2000's Avatar
could wait for another one to show up for sale , that one that attaches to the bumper beam would proably be the least visable, but as said i would prefer the hidden hitch one over that, due to no drilling installation and such
painting it all black will definetly help hide it under the car more/make it less noticeable
or maybe instead of just black, cover the majority of it with undercoating to match the rest of the undercoating on the car, then just leave the last couple of inches of it painted black so the undercoating does not interfer with the operation of it (pins sliding in and such)(basically the safty chain loops back would just be painted, and every thing foward of them be undercoated)
what ever you do to it, it will still be visable, it's just a matter of how visable (or not) you make it and such
Old 01-22-2010, 11:40 PM
having a hitch is gonna be good, can haul a lot more crap than before.
Old 01-22-2010, 11:43 PM
B A N N E D
friesm2000's Avatar
hot tub delivery service
Old 01-22-2010, 11:47 PM
HAHAHAHAH yea right.. the trailer alone would max the shit out of that. and the tranny would be crying for help. the mdx has taken a beating due to those tub moves. you shoulda seen the BROWN burnt tranny fluid YIKES...
damn tho i cannot wait to get back into biking... and this hitch is gonna make is sooo easy.
Old 01-22-2010, 11:58 PM
B A N N E D
friesm2000's Avatar
car is rated to tow 2000 pounds from the factory (with 200 pounds weight), so the tranny will be perfectly fine, especially if you add an externial cooler to it
and yeah if i biked (or something like snowboard) on a regular basis, i would proably prefer the hitch, pull one pin and the rack is off the car, let alone never touching the paint (just make sure the bike does not sway at all though), but also the load is behind the car, so no additional wind (actually a little does, but not much at all)(on the highway) has to be broken, so less drag overall, so better MPG, let alone less load on the tranny itself from the smaller amount of drag
Old 01-23-2010, 12:06 AM
B A N N E D
friesm2000's Avatar
also make sure to get a new hardware kit too (part # is in the instructions above ^^^), better safe then , let alone having to proable deal with how bolts and such like to sieze up with where you live
also for the undercoating, make sure to not spray the mounting flanges with it, and only use paint there (don't want something crushing in between the mounting flanges, and not letting you achieve the proper torque on the bolts themselves), but once installed, i would say cover those bolt heads and such in the undercoating to help seal them up also
Old 01-23-2010, 12:13 AM
OR i can postpone that an finish the car.. get the XLR8 cat and CT mufflers and then I can stop with the car and move on..
i duno what you all thinK?
spend money on car and finish it... or
spend money on physical health/fitness?
Old 01-23-2010, 10:57 AM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,192 Likes on 4,836 Posts
Car.
Old 01-23-2010, 11:34 AM
B A N N E D
friesm2000's Avatar
also when you do start doing that delivery service, you need lighting also, so:
http://www.etrailer.com/pc-VWH~43105.htm
plug and play, so can't complain of that
Old 01-23-2010, 11:45 AM
Justin's
98JDMCL's Avatar
get roof racks and call it a day lol
Old 01-23-2010, 11:48 AM
i got my heart set on the one bike in Charlotte NC. I'm willing to drive down and get it. but if i cannot get that one I think I will just get the car finished and then get a bike when a good deal pops up.
I heard a couple sounds clips of comptech mufflers and I was like OMFG!!!!!! i gotta get them. price is just an obstacle
Old 01-23-2010, 11:54 AM
civicdrivr's Avatar
If you do drive down to Charlotte, let me know when youre passing through VA, you can hear the CTs in person
x2 on the roof rack. I love roof racks on slammed Hondas.
Old 01-23-2010, 11:59 AM
lol good point.. if i mission all the way into the US, i will stop by and meet a few of you avid Aziners.... no other tyime will i have a chance to chillin with you all :-)
Old 01-23-2010, 12:05 PM
Justin's
98JDMCL's Avatar
Slammed on rackz is dirty!
Old 01-23-2010, 04:03 PM
looks like I'll be getting that hitch and a bike rack asap... then driving down to north carolina to grab that BIKE (once i save up some more FLOW).
SEXY specialized mtb should B a fun ride!
Old 01-23-2010, 05:37 PM
civicdrivr's Avatar
SEXY specialized mtb should B a loooooooooong ride!
fixed
Old 01-23-2010, 05:48 PM
k so i think I will give u aheads up civic b4 i head down there.
Old 01-23-2010, 08:40 PM
civicdrivr's Avatar
Cool. Id like to check out you car
Old 01-29-2010, 09:00 PM
camaroracer016's Avatar
hitch? cmon dude...
Old 01-29-2010, 10:02 PM
yea not anymore no more bike for me I'm gonna finish the car off. I got to
Old 01-30-2010, 12:16 AM
civicdrivr's Avatar
lol
02-25-2020 09:57 AM
james357
02-13-2016 02:37 PM
nanos
11-12-2015 08:41 PM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Mikehxbx
08-31-2015 10:17 PM
Quick Reply: will this hitch fit my car?
