Why rub??????
Old Dec 5, 2001 | 08:07 PM
laser1180's Avatar
Why rub??????
I just bought a set of 18 x 7.5 with 235/40/18. and the offset is 45. I am rubbing the back tires whenever i hit a bump, are my tires tooo wide or what? will 225/40/18 rub? thanks alot!
BTW I am using Eibach spring.
Old Dec 5, 2001 | 08:32 PM
BLK CLS's Avatar
Stealth Bomber
Are you sure your offset is not too low?
Did your car have a lot of people/stuff in it?
Old Dec 5, 2001 | 10:28 PM
soopa's Avatar
The Creator
hmm...
i have 235s on a +45, 8" wheel. And mine rub at just about an Eibach drop.
so I guess... with 235's you could possibly rub... although +45 should be a plenty high offset for a 7.5" whelel.
Not sure tho.
Your probably rubbing on the inner fender lip... just roll it back a lil.
Old Dec 5, 2001 | 10:47 PM
EricL's Avatar
Re: Why rub??????
HRE suggested that +52 would be optimal in a 7.5" wheel width.
225/40-18s could help. However, you would want 225/45-18s (SL ok) or 225/40-18s in an XL tire (Nittos and/or Toyos)
As soopa said, you could try a little fender "trimming" if the rub is at the rear fender..
Can you check for rub marks? It would help determine the next step.
Old Dec 5, 2001 | 10:52 PM
laser1180's Avatar
I checked, it's at the back, the inner fender, i wonder if i go back to 225/40, since it's 10mm smaller, would it be alot better? cuz now, 235/40, the ride is PERFECT, and it's not bumpy at all, maybe the extra sidewall compare to 225.....
Old Dec 5, 2001 | 10:54 PM
EricL's Avatar
If the ride is perfect, you may want to talk to soopa and there is a thread from only a few days ago about cutting the plastic in the rear fender area.
You MAY be ok with the 225s, but I'm not sure...
Old Dec 5, 2001 | 11:15 PM
laser1180's Avatar
I think i should be ok with 225, cuz i did some calulation. 235 Vs. 225, the difference are 10mm, which is about the size of the inner fender. And with 235, i am out to the fender by too much. The offset 45, they should be ok, cuz someone with 42 offset but with 225/40 tires, still have no problems running. I try to switch to a 225 to see.
Old Dec 6, 2001 | 12:58 PM
laser1180's Avatar
Old Dec 6, 2001 | 01:08 PM
CO-CL-S's Avatar
You did remember that the outside of the tire will only move in 5mm when you go from 235 to 225?
Old Dec 6, 2001 | 01:10 PM
soopa's Avatar
The Creator
WTF? Your rubbing on the INSIDE?
Are you sure...?
I have had mine dropped pretty low and cant manage to get it to rub INSIDE its always outter fender.
Old Dec 6, 2001 | 01:24 PM
soopa's Avatar
The Creator
ya know if your rubbing inside... i dont know how to fix it... i would suggest putting on some spacers maybe and then fix the rubbing on the outside... which is always easier.
i dunno
Old Dec 6, 2001 | 04:54 PM
blxmjx's Avatar
foolio at heart
You are probably rubbing with the 235's because of the extra bulge that you have on 7.5's. If you were running the 235's on an 8" wheel there would be less wheel bulge and you possibly wouldn't rub. I was running +48's when I had 235's and I had no rub on 18's but then again my rim width was only a 7"
Old Dec 6, 2001 | 07:55 PM
EricL's Avatar
Strange as it may sound, the 7.5s will reduce the cross section by .2" per .5" of rim reduction (within the recommended rim width range). There are always exceptions -- and that is the "rule" I found at various tire sites...
laser:
I'm wondering (given the info) about your comment about “inner fender”…
Are you talking about the outboard fender, but the rub is on the inside of it?
OR
Are you talking about the inside of the fender well. As in the rub is happening on the tire tread or sidewall *away* from the "outside" tire (visible) sidewall?
<pre>
<font size=+1>
Fender well on rear of driver side
|A B| <-- (outside of car’s fender)
| | Tire | |
| |<-- inside | |
|C | |D-+ <-- (fender lip)
</font>
</pre>
-end diagram-
Given the diagram above, can you specify if the rub is at:
A or B or C or D (or at somewhere between them)?
Old Dec 6, 2001 | 11:13 PM
laser1180's Avatar
Thanks guys, solution solved! 225/40/18 will not RUB, maybe once tiny one every now and then at big bumps... but other than that, no more rub. Wow, i didnt know 235 Vs 225 can make such a big diff. thanks guys
Old Dec 6, 2001 | 11:57 PM
EricL's Avatar
Just curious -- (for future reference) -- where on the diagram did you rub with the 235s?
Old Dec 7, 2001 | 01:04 AM
laser1180's Avatar
D where you need to roll the fender part
Old Dec 7, 2001 | 04:25 AM
amir was here's Avatar
@ 225 40 18, how accurate is the speedo?
also, you have ANY rubbing with 225's?
what about when your car is filled?
and your lowered with the pro-kit right?
Old Dec 7, 2001 | 01:54 PM
bump
Old Dec 7, 2001 | 02:58 PM
EricL's Avatar
Thanks, that makes perfect sense now!
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
