Who has pulled their engine?
Old Jan 12, 2008 | 01:19 PM
silvervtec96's Avatar
Back to a MT!
I'm looking to pull my engine from my car to the timing belt, water pump, motor mounts, a/c tensioner, clutch and valve adjustment. Figured it would be much easier to do all outside the engine bay.
Any one who has done this have any advice on this topic. I searched for engine removal and dropping engine and didn't really find much.
Thanks.
Oh, I'll take lots of pictures when I do it though!
Old Jan 12, 2008 | 02:15 PM
underst8's Avatar
140,000 miles young
IDK man i'd say that is a lot more work than would be just to do that maintenance in the engine bay.
Old Jan 12, 2008 | 03:29 PM
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
taking the engine out is not hard what so ever in our cars. just make sure u got a nice place to work at and have tools.
Old Jan 12, 2008 | 10:48 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
change the main seals while you're at it
Old Jan 12, 2008 | 11:40 PM
Nutshell's Avatar
main seals for sure. but you dont really have to pull the engine for all of this. the clutch will require a tranny drop but other wise everything can be done under the hood.
Old Jan 14, 2008 | 06:18 AM
Back to a MT!
Ya, I kinda figured the engine drop would be over kill, but thought it would be fun and make it easier to do the work on the engine! Plus I was going to put the epoxy in all my engine mounts. I'll see how it all goes. Thanks for the advice!
Old Jan 14, 2008 | 07:47 AM
fsttyms1's Avatar
Ive pulled my motor before,you could pull the whole thing in a matter of 2 hrs (or less for those who have done it before). Its VERY easy on the TL. Unhook a few things(rad hoses ps pump a few grounds, shifter cable and unplug a few connections on the drivers side), pull the wire harness (unhook from ecu) thru firewall and leave attached to motor, un hook exhaust from cat, leave trans attached lift from the top. As your lifting separate the axles from trans that way you dont have to take them out of the knuckles.
Overkill for what you want to do but not that hard to do
Old Jan 14, 2008 | 08:28 AM
Soccer_playa1579's Avatar
i think thats a good idea =). just make sure u plug everything back in before you fire that bad boy.. lol
Old Jan 14, 2008 | 09:07 AM
Back to a MT!
Did you lift the engine out or drop it out? The manual says you drop it out the bottom...but it would be much easier to pull it through the top.
Part of me wants to pull just to do it! Then I can clean it up and see how everything works...dam engineer in me!
Old Jan 21, 2008 | 08:21 AM
Back to a MT!
Has anyone pulled their engine from the top, or is dropping it the only option?
Thanks.
Old Jan 23, 2008 | 04:06 AM
mordor110's Avatar
Nick
If you drop it you have to remove the sub-frame and I think this will throw out the alignment when you put it back together, so you'll have to get it aligned afterwards. I'm not sure if you can pull it from the top and leave the sub-frame/cross member in place? I seem to remember a service tech @ the stealer telling me it had to be moved to pull the trans to do the clutch also.
Old Jan 23, 2008 | 08:10 AM
fsttyms1's Avatar
I posted in my post to pull it from the top.Its VERY EASY You will have to remove the hood struts and stand the hood straight up or remove it (which isnt hard to do)
If you drop it you have to remove the subframe and bumper, then find a way to lift the car over it.
Old Jan 23, 2008 | 12:54 PM
Back to a MT!
Thanks! I'm not sure if I will pull it, but I'm leaning to pulling just to do it!
Old Jan 28, 2008 | 09:31 AM
PowerRev's Avatar
If your goin to do all that while doing a clutch, You might as well pull out the engine. The only thing that makes taking out a engine long is pulling out axles, and mounts, and since axles are coming out anyways, you should just take out the engine. You will be happy you did when doing the timing belt.
Old Aug 7, 2010 | 07:34 PM
jutsinn's Avatar
Sorry to bring this old thread back, but I'm pulling the motor on my 03 Accord and can't find any info on that so I figured i'd look here since they're very similar cars.
Manual says to go from the bottom but since I'm working out of a garage w/o a lift I would rather go from the top, is it possible to unbolt the motor from the trans and just pull the motor or is there not enough clearance to slide the motor off the trans shaft?
Old Aug 7, 2010 | 07:50 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
manuals are easier to pull out from the top.
Old Aug 7, 2010 | 08:40 PM
jutsinn's Avatar
That's what I was hoping for as I'm working without a lift, can you slide the motor off the trans or will I be looking at pulling the trans as well?
Old Aug 8, 2010 | 03:11 PM
nspec_ya4's Avatar
what i meant to say was u can pull the motor and manual tranny out together from the top.
as far as removing the motor with auto tranny together, u can only take them out from the bottom.
You will have to separate them in order to take the motor out from the top (in auto)
Old Aug 8, 2010 | 04:29 PM
fsttyms1's Avatar
Pull the trans with the motor. You will thank yourself later. Unbolting it is much easier outside of the car, and mating them back together is much easier outside the car.
Old Aug 8, 2010 | 04:31 PM
fsttyms1's Avatar
I got mine out with the auto trans attached. If you have a engine leveler you can tilt the motor and trans to get it to clear
Old Aug 9, 2010 | 10:28 AM
jutsin's Avatar
3rd Gear
Thanks for the advice. I'll try to get the garage cleaned up and hopefully start on it today
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
ghuns
Sep 16, 2015 04:26 PM
HeloDown
Sep 8, 2015 06:51 PM
