Who has had timing belt replaced here?
How many of you guys have had your timing belt replaced? Cost? mileage? I'm hearing nearly 800, I have 95K on it and the service mgr sez it shld be done at 105K. I don't think I feel like waiting till then. Opinions? Thanks
If you are going to drive the car past 105k, there is nothing to gain by putting it off. If you want to do it now, I'd do it. The only way you lose is if you sell or total the car in the next 10k.
Price sounds right, $800 what it costs in Texas with a water pump.
Just got off phone w/ svc mgr again--he stressed it doesn't need to be done till 105K. I said if it goes before then, "I'm holding your ass responsible." Silence. "Ummm, maybe you will want to do it sooner, y'know, whatever makes you feel better." Yup, I'll hold out for 5K then it gets done for sure.
I'm a little worried about this too since mine is at 81k. I've had it done to another car and afterwards it pinged like crazy and had less power. They must have not lined up the cam and crankshaft teeth properly. We sold the car soon afterwards. Another freind had it done to her pathfinder, at the dealer, and similar results. Never ran the same. I dont think these guys are careful about lining up the cam and crank marks. This is critical to the process. Tell them when you have it done that you are worried about this and want someone who is careful about it and that you'll be back if it isnt right.
On my Gen II Legend Coupe I paid about 800 dollars to have the dealer replace it at the suggested 90,000-mile mark.
The price DID include a new water pump as well because it’s driven off the same idler and Acura recommends replacing them both at the same time.
They said if you just replaced the belt it would burn up the old pump and you’d be back in the shop a couple hundred miles later.
I don’t know if it’s a similar design for the CL & TL 3.2 engine or if they changed that.
the life of the belt is more based on actual years, not mileage. A guy on the TL site fsttyms1 (PM him for lots of good info) has 180+k on his 2000 TL with the original timing belt. Now that is pushing it, but the 105k mark, is just a reference point - not a 100% thing. But it will need to be replaced, so if you are going to keep it for a while longer, get it replaced (with the water pump). and the $800 price is normal.
I don't know that a new belt would automatically kill the pump within a few hundred miles, but the water pump needs to be removed to replace the belt so you might as well replace the pump with a new one while you've got it off.
Originally Posted by ou sig
the life of the belt is more based on actual years, not mileage. A guy on the TL site fsttyms1 (PM him for lots of good info) has 180+k on his 2000 TL with the original timing belt. .
Our T.Belt is very well made and I have not seen one break, but on older integra belts breaks at around 70K-90k miles. If belts breaks, 99% of the time you will need a valve jobs, that will cost $2k.
You think mine would last for 10-Years?
Shawn S… Who only drives 9-10K a year.
Where did you get the info that belts life is base on actual years and not mileage?
Does anyone know what type of belt do we have?
It depends on a car, on some cars if it breaks it might cause a severe damage, while on others if it breaks your car will just need to be towed, and they will put a new one.
Did a T Belt on a Nissan lately.
Even the parts alone are not so cheap. Just did an old Nissan V6 myself. Just below $250 in parts alone including WP, T Belt, Tensioner, Thermostat, hoses. With a discount using Nissan parts. Could have spent even more by replacing the external belts, but changed those 1 yr ago.
Hope my Honda will not cost $1200 to get the job done by a mechanic.
I went to my mechanic (not an Acura specific mechanic, but still very good) and said he would do mine for $395. I know he's not an Acura tech, but he does very good work (he's done everything I've needed done on all of my cars since I was 16) I would trust him to get it done.
he said it would take about 3-3.5 hours to get it done. I have 80K on the car now and was going to get it done a couple of months ago, but he suggested that I wait until 100K to get it done. However, I will not have the car that much longer.
B
B
did mine last week. took about 4 hours. 65k miles. im not one to take chances with interference motors. old belt seemed to look good. but i run my car harder than others and like to have the peace of mind im ok.
My car is in right now for the timing belt replacement. I'm having the water pump and all exterior belts replaced as well. $685 for the whole package. They found a problem with the timing belt tensioner and are replacing it. My car just went over 111k miles and has only been to the shop for oil changes and a transmission at 65k. I'm also having the radiator and transmission flushed and filled.
That's an awsome deal...I have 114K miles on my 01 CLS, time to get the timming belt service done. Anyone in the North TX area know who has the best deal?
i have 86xxx miles on my car and i went to my local acura dealership to get all the external belts and waterpump replaced just a couple days ago. basically, the 105,000 mile service. there are 2 dealerships in jacksonville and one for some reason, is always more expensive than the other....no idea why. but anyways. i of course, went to the less expensive one. the complete 105,000 mile service including all belts being replaced, waterpump, and spark plugs was 1,200. i opted to exclude the replacement of the spark plugs because that service added an additional 300 dollars! thats a ridiculous price to replace em imo. so with my belts and waterpump replaced i paid $700ish. oh and it took from 8am-5pm. and they gave me a 04 tl as a loaner car
SPEAKING OF BELTS.........HOW DO I GET MY SRS LIGHT TO GO OFF??? I HAVE HAD IT ON SINCE I HAD MY CAR IN THE AUTO BODY SHOP GETTING THE KIT ON IT? I SAW A THREAD ABOUT TAKING THE NEG. BATTERY TERMINAL OFF FOR A HALF HOUR, BUT THAT DIDNT WORK!
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
