where to resurface Slotted and drilled rotor?
Old Jan 18, 2010 | 04:08 PM
qwpobird's Avatar
just wondering,
where do you guys resurface your slotted and drilled rotor?
I went to pepboy and firestone, they told me it can't be done. is that true?
The reason I want to resurface is because the shaking while braking, it's really annoyed. and my pads(Red stuff) are just less than 3k, should I replace them as well?
Thanks in advance
Old Jan 18, 2010 | 06:09 PM
CH46ESeaKnight's Avatar
It can be done, I had the EBC sport slotted and dimpled rotors and have them turned for my Tahoe due to a light glaze from an emergency stop. It can be done. Have no clue where in GA though. Mine were done in Colorado Springs. I see you have good rotors, are you sure that it is the rotors? Were the red stuffs and the rotors new when you put them together? Or was one used?
Old Jan 19, 2010 | 09:37 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
WHy would you turn the rotors because of an emergency stop... When u slam the brakes on HARD, u get massive heat buildup on the outside of the rotor and then u get a blue line or some color change on the rotor where the pad was hitting the hardest.. that'll go away with normal driving after like 60miles. I've have that happen to my DBA front rotors plenty of times already and it always goes away.
my personal experience with turning cross-drilled and or slotted rotors was a complete failure. the metal was too thin and the heat would instantly warp the rotors making the wheel shake to the point the car felt like it was an airplane in turbulence.
OP if ur gonna get new rotors get DBA fronts and you will be in heaven. they are Pricey but DAMN they are the best looking and the best functioning rotor ive ever used or seen.
WATCH THIS VIDEO... this is what made it a NO brainer for me
http://www.youtube.com/watch?v=8PzWFn6lGBs
Old Jan 19, 2010 | 12:00 PM
OperationDarkie's Avatar
Ultra Negro
just buy another set in my honest opinion, because as far as I know you can turn slotted and crossdrilled rotors.
Old Jan 19, 2010 | 12:14 PM
SG81's Avatar
Missing My CL-S
i've never tried to resurface my slotted rotors, but i've always been told you shouldn't
Old Jan 19, 2010 | 12:57 PM
civicdrivr's Avatar
Its difficult to resurface them. Very few shops are willing to do it, and even fewer know what they are doing.
Old Jan 19, 2010 | 01:23 PM
Because I had to stop 8,000 LBS on a down grade from 80 mph. It put a thick glaze on them. Not just color change.
Also just turning your rotors once is not enough to make them so thin they are no good or as you said "warp Instantly". It was not from turning them, it was because you were an idiot and got the cheapest sets of brakes you could find on ebay. Then used old pads with new rotors and vice versa. Did you not say you went through like 6 sets or something before you got a decent set. You act like they take of a 1/4 inch. You make no sence.
You are the absolute last person I would take brake advice from.
Also the OP already has DBA's.
Old Jan 19, 2010 | 01:26 PM
I think that is the key, finding a shop that knows what they are doing.
Old Jan 19, 2010 | 01:44 PM
no i went through one set of ebay rotors... and then I made them ship another front set to me cause I was convinced they were shit, and they sent me new pads, so i had rotor set 1 the OEMs, the original ebay front set and then the ebay 2nd front set... I had OEM pads, new high performance pads and then a ceramic set sent by the ebay DLR since I bitch them out so hard.
I had ordered the same set before and put them on my probe with no problems... I had NO idea I'd unlock a nightmare as I did
So 6 arrangement of pads/rotor combos...
turned out it was a combination of a cross balance issue with the tires that happened right after I changed the brakes the first time, weird ass fluke... leading me to believe it was the rotors or the brake job i did. The belts on 2 or 3 of the tires were screwed, not to mention all the tires had different wear... bought the car like that. and i think the rotors weren't up for the weight of the car and warped instantly.. i figured tho, if they worked once they'll work again... wrong i was
And I re-used my high performance pads on my DBA rotors by sanding them and they work fine... so plz spare me the old pad on new rotor story... anyone who blames that is either using pads that are like 10% left or they cant sand a flat surface.
you have a good memory though
I brought my car to shops and they all told me they dunno wtf it is. i had to figure out it was the tires myself. coulda happened to anyone.
lol and my bad for not reading his sig....shoulda read it
Old Jan 19, 2010 | 01:51 PM
I just went back and read my post, I should not have called you an idiot. Sorry bout that. Besides I might be moving to your neck of the woods, so I should be nicer so I don't get my ass kicked!
OP you should try some speed shops in your area, they likely won't do it but may know who can.
Old Jan 19, 2010 | 02:04 PM
sall good man, i don't take offense to very much... things just happen.. and it's human nature to put the blame somewhere. that's just how we are.
my neck of the woods? whereabouts you thinking of moving?
lol not many trees in toronto and mississauga
Old Jan 19, 2010 | 04:01 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I"ve had 2 sets, and replaced them both times, running my 3rd set now
Old Jan 19, 2010 | 04:03 PM
set of which brand rotors? ^
Old Jan 19, 2010 | 07:36 PM
Allout's Avatar
Blown is Best
I've been told that it's easily done. Just need to use a sharp tool on the lathe.
Old Jan 19, 2010 | 08:10 PM
lol i hope ur joking
OP I went to many places and they were telling me no cause of the drills and slots... they actually wear out the bit they use to grind the rotor down. and that bit is not cheap. so it's usually not worth the time nor the cost to have it done.
Old Jan 19, 2010 | 08:59 PM
Allout's Avatar
Blown is Best
http://www.ffcobra.com/forums/showthread.php?t=218974
Old Jan 19, 2010 | 09:54 PM
civicdrivr's Avatar
Good info.
Old Jan 19, 2010 | 11:19 PM
Jacobpockros's Avatar
I have been using iRotors drilled & slotted rotors with OEM Acura pads and i have never had any problems from them (and I drive and brake like im racing on a track).
Old Jan 20, 2010 | 12:20 AM
qwpobird's Avatar
both rotors and pads are brand new, it worked just fine in the first few months(a little noise). but now it started shaking while I hit the brake.
Old Jan 20, 2010 | 12:26 AM
qwpobird's Avatar
well, I have green stuff ready to replace with the Red stuff. (Red's heavy dust is very&)*&#%).
Old Jan 20, 2010 | 12:40 AM
civicdrivr's Avatar
Ive heard the green stuff pads dust more then the red stuff.
Old Jan 20, 2010 | 10:54 AM
green stuff should make more dust since they are a softer composite. My buddy's has them on both of his cars and they SHED brake dust all over the place
Old Jan 20, 2010 | 11:22 AM
it is the other way around. The reds dust alot more than the greens. I've used all the ebc brakes before, on many applications. I've even used a set of Bluestuff pads. The reds dusted more than anyother pad I have ever used, but they were also some of the best pads I've used for stoping power. The Yellow's have been great on the CLS. Low dust and great stopping power. Well, as well as a CLS can brake anyways.
This im my experience anyways.
Someone try these, I've read hundreds of great reviews for them by track guys. A lot on the Corvette forums, and Mazda weekend racers. If I get a CLS6, or what ever I get to replace my 01CLS, Im going to go with the Carbotech pads and DBA rotors. Here in the link.
http://ctbrakes.com/
Old Jan 20, 2010 | 11:51 PM
qwpobird's Avatar
WTH,, Green is worser than Red ... I should have done some research :'(
by the way, I have EBC slotted rotor with Green on rear set..
Old Jan 22, 2010 | 12:11 PM
qwpobird's Avatar
do you guys think 80 bucks is a reasonable price for turning two front rotors? well, my dba rotors.
Old Jan 22, 2010 | 01:01 PM
YES! The Acura dealer charges around $200 for turning 2 rotors.
$80 is a STEAL. Do it
Old Jan 22, 2010 | 01:19 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
u can get those shaved at machine shops.
Old Jan 22, 2010 | 02:34 PM
NO WAY, $80 is way high. Should not be more than $20 each. Just because the dealer charges $200 does not mean you should get raped somewhere else. Besides the dealer I've never seen anyone charge more than $20 each.
Old Jan 22, 2010 | 02:35 PM
Allout's Avatar
Blown is Best
I personally wouldn't do it. I would take the $80 and apply towards a new set of rotors. By removing more mass off the rotors, you've reduced the heat capacity and increased the possibility of them warping.
Old Jan 22, 2010 | 02:38 PM
Did you call DBA? Maybe they will warranty them?
Old Jan 23, 2010 | 01:53 AM
qwpobird's Avatar
seriously?? does warranty cover that??
the brake shop asks me if my rotors are on the car, Probably it would be cheaper if I take it off and just bring in the rotors right?
I bought my DBA on autoanything.com, should I give autoanything a call or dba company??
Thank you guys for answering my question. I think I will do it very very soon. Thanks again
Old Jan 23, 2010 | 10:30 AM
civicdrivr's Avatar
Call DBA directly.
Old Jan 23, 2010 | 12:01 PM
my dba fronts are good still after 10000kms roughly, and I do do some mental braking when I decide to go up to 200 here and there... but the rears are simply too small.
Why can I not put the fronts on the REAR and get a front BBK???
is that possible?
Old Jan 23, 2010 | 12:09 PM
civicdrivr's Avatar
You'll need a new bracket for the rear caliper, but most importantly you'll lose the e-brake.
Im thinking something up for the rears though to go along with my BBK up front. Once I get it figured out and made up Ill post it
Old Jan 23, 2010 | 12:13 PM
oh i'll luv you for that bro
Old Jan 23, 2010 | 12:52 PM
How long ago did you buy them?
Old Jan 23, 2010 | 02:46 PM
qwpobird's Avatar
well, I bought my dba around the christmas day, and have it installed around around feb 1st.....
I don't mind getting a new set of rotors, because i think brakes are the most important components in terms of safty issue. However, I do want to save some money. Brakes aren't cheap.
Old Jan 23, 2010 | 06:46 PM
Christmas of what year?
Old Jan 23, 2010 | 06:47 PM
celynka's Avatar
Sundance Gold in
It can be done but ... drilled and slotted discs wreck the baldes and equipment so fast that is not worth to resurface them for the shops ... get a new ones
Old Jan 23, 2010 | 06:50 PM
celynka's Avatar
Sundance Gold in
oh! and do not get those super duper 100k ceramic pads next time. That junk lasts much longer but galzes and overheats your discs. I'd rather change my pads ever 25k than replace rotors!
