where is this plug??
9th Gear
I just recently noticed that my 3rd brake light is not plugged in. I had some new speakers put in the back and think that they may have hidden it. Been pulled over once for no light, cant afford a ticket. can anyone tell me where the power lines originate from back there so i can plug it back in?
thanks in advance
thanks in advance
Doubt they inplugged it.. Mainly it's inside the spoiler.. More then likely if you had audio work done then they blew a fuse.. Just check the drivers side and passenger side fuse box..
9th Gear
i have looked everywhere in the trunk, nothing. the only think i can think of is that when the guy installed my rear speakers he left the harness up in the rear deck or something
9th Gear
yeah, i did. it shows it coming from the same area as the trunk light. i dont see another harness anywhere around it. do any of you have a 2001 that you could check to see where yours enters the trunk from?
As was just said... The connector is removed from the third brakelight when you have a spoiler added with an LED light. The connector is then connected to the spoiler light thereby leaving the original third brakelight disconnected.
DO YOU HAVE A SPOILER????
If you don't have one, the cord should be under the rear shelf within the trunk cavity, not
under the shelf itself within the cabin of the car.
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
