Wheel locks
Old Nov 27, 2002 | 09:50 AM
260's Avatar
260
Wheel locks
How effective are wheel locks? The factory ones seem all identical so i was thinking of getting some "super wheel locks" from somewhere. Dont want to get my lowenharts jacked. Any tips etc...
Old Nov 27, 2002 | 09:58 AM
juniorbean's Avatar
you're probably better off getting aftermarket wheel locks...but honestly.. .the Acura's are fine. They are all different, otherwise it would kind of defeat the purpose.
What a lot of people do is have the Acura locks AND aftermarket locks on each wheel. Two locks per wheel = double protection
Old Nov 27, 2002 | 10:06 AM
Shawn S's Avatar
Go with “The System” from Gorilla. That’s what I have.
EVERY lug is a lock and the key interface is on the SIDE of the lug, not the end.
Very hard to defeat and there are over 10,000 possible keys.
And all (20) lugs are exactly the same so weight and balance isn’t an issue either.
The Acura OEM locks are CRAP.
I forgot to give the key to them one time during a service appointment and the guy told me not to worry because every shop has the entire set.
He didn’t tell me how many, but I suspect only about 15-20 otherwise they would have called and asked for my key.
Go with Gorilla or another comparable aftermarket set.
Shawn S
Old Nov 27, 2002 | 10:08 AM
jimcol711's Avatar
when i had stock wheels, i had the acura OEM locks, the dealer gave them to me for free so i couldnt complain, now ive got aftermarket wheels that came with different locks and whats cool is that EVERY one is a lock, much like shawns...very nice.
Old Nov 27, 2002 | 10:18 AM
tw1112's Avatar
Yeah the acura ones are very easy to defeat. I recently had my brake pads changed and forgot to give a local garage my wheel lock key.....well they had no problems getting them off and didn't have to call me to ask where my key was.
Old Nov 27, 2002 | 10:47 AM
JasonT's Avatar
Are the lockss the same size as stock. Menaing will the lug wrench fit. I got a set of the Gorilla ones for my explorer, but I can't use them becaue the lug wrench doesn't fit.
Old Nov 27, 2002 | 10:54 AM
OUTRAGEOUS CL TYPE S's Avatar
1 Phat CL !
i have mac guards any 1 here anything bad?
Old Nov 27, 2002 | 11:22 AM
SickCL's Avatar
Lone Star Rider
McGard manufactures the oem wheel locks.
Old Nov 27, 2002 | 11:31 AM
fulltrunk's Avatar
East Oakland Representer
GO WITH THE GORILLAS. ESPECIALLY IF YOU'VE GOT LOWENHARTS. I'M WAITING ON MY BR5'S NOW, AND THEY WILL HAVE 2 GORILLAS ON EM
Old Nov 28, 2002 | 06:31 PM
1 Phat CL !
what does that mean, Mcgard manufactures the oem wheel locks, I was talking about protection wise, they shouldnt have a copy at the dealer.
Old Nov 28, 2002 | 06:32 PM
1 Phat CL !
i'm gonna try it next time i go to the dealer, ask them to rotate my wheel and i'll hold on to the key we'll c what happens
Old Nov 29, 2002 | 05:45 PM
SickCL's Avatar
Lone Star Rider
Most if not all dealers have a "master" wheel lock key set.
They just use in case you loose or misplace your key. I believe also some major shops can have access to the set.
Try holding on to your key, and sit back. Next thing you know, Mr.
John Doe, your car is ready.
Old Nov 29, 2002 | 07:52 PM
1 Phat CL !
this week, we'll find out
Old Nov 29, 2002 | 07:58 PM
JakeCL's Avatar
wheel locks are easy to get off w/out the key all you need to do is hammer a bigger socket bit over the top so its real tight around the edge and you can turn them off
Old Nov 29, 2002 | 09:24 PM
1 Phat CL !
easily said than done, anyway, I have small lug nuts that come with the rims, if i use gorilla i think i might get vibrations because they are bigger lug nuts, not made for these, rims, i dont want vibrations, remember i'm running 19s
Old Nov 30, 2002 | 12:24 AM
Shawn S's Avatar
Well, I didn’t put them on the scale, but they look about the same size as the stock lugs.
I don’t think you will have a problem with vibrations since “the system” is specifically designed for balance.
Shawn S
Old Dec 4, 2002 | 10:31 PM
260's Avatar
260
how much are the gorillas
Old Dec 5, 2002 | 10:21 PM
Shawn S's Avatar
I paid 65-bucks for mine when I bought my Rims.
But don’t forget that’s for all (20) lugs. You don’t need anything else.
Shawn S
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
ahsm
Sep 9, 2015 08:35 AM
braveheart
Sep 7, 2015 08:12 AM
