Wheel advice needed---please help
Will 18x8.0" wheels fit on a '01 Cl with comptech sport springs. If yes, any ideas on what the proper offset should be. Thanks for the help in advance.
Mike
Mike
Re: Wheel advice needed---please help
Mike
Mike
If it were me, I'd choose 235/40-18 tires and look for 18x8 wheels that had an offset of +50.
Any idea if I can run with 225/45/18's to keep the rolling diameter the same with a +48 offset? Thanks
With 235s and a + 48 offset you definitely won't have any rubbing problems in your inside, front wheel wells and you shouldn't have any in the outer, rear wheelwells --based on all the folks running 235s on 17" SSR Competions using 45 aspect ratio tires.
Close, but W.R. is probably right about going with the 235/40-18s. The 235/40-18s have the closest revs/mile match (diameter) to stock.
BTW -- The load rating of a non-XL rated 225/40-18 is 88 (in general -- do check). IMO -- this is just way too low. The Toyo 225/40-18 is the only XL tire I'm aware of in that size (it has a load rating of 92W).
If you go with the 235/40-18 or 225/45-18 (and its not a Toyo T1S) you will at least have a load rating of 91...
Link to S03:
http://www.tirerack.com/tires/Spec.j...+Pole+Position
Link to tire calc:
http://www.miata.net/garage/tirecalc.html
Link to S03:
Link to tire calc:
Link to S03:
Link to tire calc:
Originally posted by blxmjx
Actually Nitto has an XL-Rated tire in a 225/40/18 its the 555 and its a 92W. Nitto also has a 235/40/18 in a 91W. Either size will work fine on an 8" wide wheel.
So, it does have a higher rating, but the site (this link) shows the load being supported at the max load. It is not necessarily an XL tire (or there site is as messed up [I presume it is due to the 92 vs. the 88, but…])
It would help if they put an "*" or put an XL/SL designation...
http://www.nittotire.com/tire_nt555_sizes.asp
Originally posted by H@mmerm@n
Eric, if you hadn't already purchased your current tire/wheel combo and were shopping right now, would you do the Toyos & SSR Comps?
YES -- now that Technique proved that lowering works without a problem -- YES, YES, YES!!!!
If there had of been a problem with some great future coilover or spring/shock (that I've not found yet) and the SSR/Toyos, I would be sticking with the Toyos, but would have gotten the Volks in 17x7.5” for the light weight and forged construction.
Found this topic in a search
I'm in the same situation now, I'm trying to get 18x8 inch rims with a 45 offset. Tire racks says I shouldn't go with 235/40/18, but should get 225/45/18. He says because the offset is so low, I might have problems with the 235. Is that true anyone?
I kinda want the 235's of course...
Originally posted by Water Rabbit
235/40s will give you a much closer rolling radius to stock than 225's. They should carry a higher road rating between tires of the same make as well. In fact if you're set on 8" rims I think it'd kind of a waste to get 225s, at least, I don't see any real advantage in doing so.
That was the conventional wisdom, until poor H@mmerm@n found out that he rubbed with:
SSR Competition 17x8 +48 wheels
Toyo T1S 235/45ZR17-97W* tires
Comptech lowering springs
AND
KONI SHOCKS!!!!
He gets a bad rub when he does a hard lock turn. The rub is in the front.
So, there is something going on, and until someone sorts out the compressed/closed length of the KONIS vs. the stock shocks, there is some problem out there!
(He is going to try some 225/45-17 T1S proxies. You know a problem is "serious" when someone has to get some smaller tires of the same brand *and* they are not worn out...)
Be grateful you went with 17x7.5 +52 without the konis...
Re: Found this topic in a search
1. The offset is going to be a problem if you lower with the 235s.
2. The brands that TireRack sells have an OK load rating in the 225/45-18 and the speedo will only be off a bit.
3. The 235/40-18s have the best speedo match (and better load rating), but you would probably want to watch the amount you're lowering *and* you might get some fender rub on the inside of the rear fender lip if you combined them with some wide tires (S-03s) and the 8" rims. There are people who run it, but there are little factors that can make this a "problem". If you aren't going to lower, you will probably be ok (you will have the SUV look)...
Hey Eric, thanks for the advice!
I definitely don't want the SUV look, in fact the 225/45/18 will be slightly bigger in diameter so the gap will be less. Since I don't plan on lowering, then I should be fine with either case it seems. I'll see what the tire rack geniuses think...
I'm surprised you didn't have to "do the sign of the cross" before mentioning the CLS and 91 load rated tires (nothing like being inconsistent for TireRack sales people)
(Or send your lawyer's waiver to them...)
AND
KONI SHOCKS!!!!
AND
KONI SHOCKS!!!!
"...Mike, the min and max length for the shocks is
Front: 484mm max, 347mm min
Rear: 642mm max, 425mm min
Note that this will only help you a little in lowering the car. Typically, 1.5-1.75" max is recommend for lowering the vehicle as any more tend to make the car bottom too often. Also, check the distance before you hit the bump stop. If you have any other questions, please let me know. Thanks, Gordon..."
Hope that helps someone down the road! Meanwhile, I am replacing the 235-45/17 Toyo's with 225-45/17's Thursday.
Eric, I got a reply from Koni today on the uncompressed/compressed length question:
Now, where to get the stock data (time to open the Helms...):
for the front -> 19.06" extended and 13.66 compressed
That means the max stroke is 19.06-13.66 = 5.4"!
boy, I though we had more than 5 inches of suspension travel...
Anyone got the stock shocks out with a good ruler around?
Soul_Deamon
11-13-2018 04:44 PM
BobbyGraham388
10-22-2015 05:05 PM
