Whats Wrong With My Car!!!!
okay ive seeen it posted before, but now its happening to me. the car revs from 1k-3k by itself. and it jerks when your in gear, whats goin on? every tsb ever posted has effected my car, is there a new issue thats causing this? this is also my 3rd tranny, barely replaced last month. or so. help me out.
Possibly a faulty idling valve??
My friend's '95 GS-R is doing the same thing. It revs up to 3,500 RPM by itself, comes down to 900 RPM, goes back to 3,500. It just keeps doing that while idling.
Your car is under warranty, so take it in and let us know what's wrong with it.
My car flipped out once, it would rev up to the redline on its own. Even when I was driving, It was like I was flooring it, but my foot wasn't even on the gas. I had to put the car in neutral and pull over. I turned the car off then back on and immediately the car revved up to redline in park. I got it towed and had some sensor replaced for $125. Hope this helps.
okay.. i drove it work.. when i started it up.. same problem.. hit the open road, went wot, and after hittin vtec, the problem was gone..... WIERD... maybe ill still take it in..
That happened to my roomates 96 honda accord. It would idle then go up to 3-4k rpm and then go down and keep doing it whil ein idle. Never while driving. Then her car just died like a week later. I would def look into it just so it doesnt crap ou ton you.
Originally posted by Ant7701
two most common defects...
1. Bad IAC valve
2. Low on coolant
1. Bad IAC valve
2. Low on coolant
I have to agree with Ant. IAC have not been honda's strong suit either. But they're no where close to being like the trannies.
Originally posted by GoldieAlek
3rd tranny?!?!?!?!?!? give your lawyer a call.......I would lemon it!!!!!!!!!!!!!!!!!!!!!!!!!
SUPRMN84
09-02-2015 11:50 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
