Problem with the O2 sensor and the oil pan contact.
Former Sponsor
I just got back from the dealer and I'm sorry to say, they were right. I had OBX headers installed about a year ago, and never really seen the undercarriage iof the car. Apparently, the O2 sensor was making slight contact with the oil pan causeing the light on the dsah like the check engine, vsa and the ! to light on and off. Has anybody else had this problem? the shop I had install the headers initially said that it looked like that from day one, and they would relocate the O2 sensor position slightly by rewelding the therads. It looks like a design flew to me, cuz if the engine and oil pan would have shifted, so woud the headers sinc ethey are bolted on.
I saw that on all of the OBX we did that the O2 sensor was always in a different spot .It never contacted the pan though in any of them .it sounds to me that the bung for the O2 sensor was simply not welded on straight .
Jens
Jens
rondog I have a question for you, does your car rev funny since you have the problem with the O2 sensor. I have this same problem with all the same lights coming now and the car seem to be revving alot higher then normal or is the tranny going bad?? I need to lift the car car and check my O2 sensor.
I did 4 sets of OBX headers and one set had the same problem. I was gonna do some quick fix for him but he didn't want to. I kept telling him to check on the O2 sensor but he was too lazy. I wonder how his car is now.
Former Sponsor
how could they possibly be putting these 02 sensors on different spots each time? what kind of crazy stuff are they doing there at OBX? Don't they have precise measurements to follow and stuff? I think it's time to call OBX and have them replace that downpipe man. They should own up and replace it for you if that's causing troubles.
Former Sponsor
plus, i have pretty big plans to make my car primed. alot of custom details like bodykit, modified, custom titanD19 grille, and small things here and there, stay tuned...
Thanks for the info, I need to lift my car and look at the O2 sensor before I call my dealer about it. How far does the O2 sensor need to be away from the oil pan, so I know what to look for. If the O2 sensor does not touch anything is that good or does it need to be like 1 -2 inches away.
Former Sponsor
Did your wire burn off or did the O2 sensor just cook to death because its 2 close 2 the oil pan? Where did you get your new O2 sensor from or did you get an after market. I looked at Autozone, they wanted $111.00 for a Bosch
Former Sponsor
I lifted my car tonight, The end of the O2 sensor is like 1-2" away from the Tranny and the wire does not seem to touch any thing. I had my OBX header on for like 4-5 months now with out any problems. I discounted the battery and the car still runs funny with the RPM jumping all over the place. I guess I will take it into the shop.Thanx for your help
Former Sponsor
