what is the widest we can go for 19's
Dromaeosaurs/Velociraptor
Will 19x8.5 with 235/35x19 and a comptech drop work?
if I cant do this, I'll have to go:
18x8 245/40x18 and a comptech drop....hopefully that works (?)
19x8.5 is a pushing it... u have to get almost 50+ offset and it might still rub
19x8 the offset has to be higher than 45.... and try not to use 245 tires.... use 235...
URL Not Found!
what is offset? Idiotic i know. I, too, want 19x8.5 ADR Sterlings... I don't have a drop yet, but when i do it will be close to an inch(very small) drop. so i have to get 49/50 offset? Definition pleaseeee..thanks
http://www.usacomp.com/Offset.htm
http://www.tirerack.com/wheels/tech/offset.htm
If you go 18s you can have rim widths ranging from 7.5 inches - 8 inches. Offset must be 42mm or higher...preferably in the 45mm - 48mm range.
URL Not Found!
That clears things up. . .Sort of. ..
Will ADR Sterling's fit on a 01 CLS...It only comes in 19x8.5 I have no idea on offset? What offsett do i need for NO rubbing at ALL? Thanks
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
6peedSleepR
1G CL Tires, Wheels, & Suspension
10-20-2006 04:08 PM
