What the Weight of Our CLS Rims?
Whats the weight of our stock CLS rims without the tyres mounted?
Also what is the largest rim that would fit on our CLSs. I know that it is 19" and that 20"s won't fit. But what is the widest that we can go? And what is the widest that the tyre can go?
Tnx
Juker008
Tnx
Juker008
Originally posted by Juker008
Yea teh highest that I heard that we can go is 19". Now all I need to know is how wide of a rim and tyre can we use.
Juker008
Juker008
Originally posted by CO-CL-S
Try doing a search. One big factor is springs..
Tnx
Juker008
Springs? In terms of....? Do u mean clearance? Yea that is true. Bu tis there something that can be done to offset the rim alittle to give alittle more clearance? I know that having on/off setted rims is very stress full on the suspension. But what could aftermarket suspension kits do for us? Also what would a camber kit do as well.
Tnx
Juker008
Tnx
Juker008
As for aftermarket suspension kits, and I am assuming you're talking about Coilovers, these will allow you to adjsut the height and dampening characteristics of your suspension, while allowing almost stock ride. This will also allow you to adust the height so that you can minimize rubbing in certain cases.
Camber kits will allow you to bring your camber back to factory specs for better tire wear. You can also use these to create negative cambers to the point that your tires will tuck under the wheel well, thus acheiving clearance of rubbing issues...hehehe.
2001 CLS 17x7" rims are 25.8 (early search by a member with a digital scale) to 26.5 (Chod's FAQ) and Jens got a reading around 26+ lbs.
The 2003 rims are lighter (ask Shawn).
Hey, anyone want to cut up an old worn out Michelin MXM4 to find the weight of the outermost 1/2" (just the tread) vs. the two sidewalls (as a family project) ???
It would be helpful to figure out the effects of wheel weight and diameter changes…
Originally posted by Davediego
I thought there are a few guys rollin on 19's on the board...
Yes.... done, works, no problems (offset near 50-52 helps) when car has some 2" lowering.
I guess you have to make an initial assumption about the weight distribution of your average rim. Most of the weight certainly is concentrated around the outer rim and not the spokes, but still, what is a good assumption given the fact that the more spokes you have, the more evenly the weight is distributed around the entire rim. Less spokes, more % of weight on the outer part of the rim. And of course, weight distribution of the rim affects its inertia and ultimately the results of your calculations.
Hrrm, the mind wobbles . .
OK cool I got the confirmation that 19" will fit and it works with an offset of 50-52.
But what is the widest rim + tyre that we can go? Plz rate the tyre in mm.
Tnx
Juker008
Tnx
Juker008
Would spacers allow us to run wider tyres? If so do spacers place a serious strain on the suspension?
Juker008
Juker008
Originally posted by FDao
Actually, spacers will cause your rims to stick out further than intended, thus your wide tires will rub! Don't do it.
Juker008
Consider your rims/tires wisely. I would say look for a light weight 18x7.5 or 18x8 rims with a wieght between a low 13 lbs and a max of 23 lbs. 18 lbs is good for an 18". Look for an offset of +43-+45! and my +45 are perfect, No rubbing.
Then get some 235/40/18 Toyo TS-1 and you are a happy camper! Or better some S0-3.
And do not do the 19" unless you are going with 235/35/19 and a very light weight rim like 15 lbs or so..... Those 19" are damn expensive some $400 per rim.
Good luck.
Good luck.
Ok but as for adding spacers to the rear would be ok. Spacers wouldn't desrupt the offset enough to stress the suspension right?
Juker008
Juker008
No, spacers will not disrupt the offset enough to put stress on the suspension, but why would you want to do that?
Juker008
I do like the look of spaced out tyres. And I would think that wide spaced out rims would look tight.
Juker008
Juker008
Originally posted by darrinb
damn i never knew the 2003 rims were lighter, thats one good thing about them over the 01/02 wheels. How much lighter are they??
http://www.acura-cl.com/forums/showt...ghlight=weight
Shawn weighed his 2003 tire+wheel and got 48lbs.
2001 Tire and Wheel is 52 (close enough).
2003 wheels are approx. 4 lbs lighter.
