What grade motor oil for Phoenix?
Old Mar 24, 2003 | 04:44 PM
gsrblack's Avatar
What grade of oil is specified for our CL-S? I'm in AZ, but not sure if that should matter.
Old Mar 24, 2003 | 04:48 PM
tmk70's Avatar
Masshole
I used 20/50 out there....10/40 in the winter.
Old Mar 24, 2003 | 11:51 PM
dfv3.2CL-S's Avatar
5w-40 should be good in that region. Make sure its synthetic grade. This is what i use in south TX and Laredo normally averages on a daily basis in the summer about 98 to 101.
Old Mar 25, 2003 | 12:25 AM
SanDogDewey's Avatar
5w-20 Haven't you read the manual?
Old Mar 25, 2003 | 07:45 AM
Starter's Avatar
Re: What grade motor oil for Phoenix?
The manual says 5-20 but 5-30 is also good and will cause no problems at all. Personally, I use Mobil 1 5-30, although any good brand of oil will do just fine. If you use dino instead of synthetic, just change it more often. ALWAYS use a good filter - don't skimp here.
Old Mar 25, 2003 | 09:40 AM
dfv3.2CL-S's Avatar
5w-20 was put in the engine to help Acura get Lower emission and better MPG. Nothing to do with protection. That oil grade is to thin for the southern region of USA, speciallly Arizona.
IBankMouse
Jun 13, 2020 12:53 PM
Jul 16, 2017 07:33 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
STL TL-S
Sep 23, 2015 08:52 PM
