what fluids?
Old Dec 16, 2008 | 11:25 AM
duCksterz's Avatar
what fluids?
my power steering fluid and my brake fluid is low. what the best fluid to fill it wiith?
Old Dec 16, 2008 | 11:39 AM
poisx7's Avatar
oem
I wud just go to any carauto place. (autozone) oriley etc
they shud have what u need.
I dont think its as critical as the auto trans fluid.......... or honda coolant fluids. etc......
Old Dec 16, 2008 | 11:49 AM
poisx7's Avatar
but use honda brake fliuld.
genuine Honda DOT 3/4 fluid.
I think any wud do as long as its NOT DOT5/silicone.
but use honda fluids if u can........
Old Dec 16, 2008 | 02:14 PM
NSXNEXT's Avatar
Honda Honda Honda.
tranny, brake, power steerings fluids. Antifreeze too.
Use whatever oil floats your boat.
Old Dec 20, 2008 | 12:40 PM
russianDude's Avatar
Originally Posted by NSXNEXT
Honda Honda Honda.
I think its OK to use non-Honda fluid for brake fluid as long as its DOT3.
Old Dec 20, 2008 | 01:06 PM
CL-Slick's Avatar
Chillin' in my trailer
I am running Prestone 50/50 coolant without a problem in my CL-S. As for the other fluids, they are all Honda.
Old Dec 20, 2008 | 02:49 PM
sgmotoring's Avatar
Bleed Honda Blue
Since you have all Honda fluids, must as well go with Honda 50/50 coolant! I swap my out for the HONDA BLUE color coolant!
Old Dec 20, 2008 | 07:34 PM
TOTAL~LUSH's Avatar
is there other coolant that is accetable to use?
Old Dec 20, 2008 | 07:40 PM
sgmotoring's Avatar
Bleed Honda Blue
Just used Honda pre-mixed 50/50 coolant. It is about the same price as other coolant. Used Honda oem fluids and you don't have to worry about what is recommend and what is not.
Old Dec 20, 2008 | 11:55 PM
CL-Slick's Avatar
I'll get around to changing it eventually. I was in a bind and needed coolant ASAP so I got that.
Old Dec 21, 2008 | 08:43 AM
poisx7's Avatar
Apart frm the price reasons ???
the answer is already there. UNless u want to use h20 100% which i think is a lot cheaper.
Old Dec 21, 2008 | 09:04 AM
poisx7's Avatar
to be honest i dont think there is NY THING HONDA COOLANT WILL HAVE THAT U CAN NOT GET FRM OTHER COOLANTS.
pRESTONE i think is cool.
I even mixed mine with some cool water when i got to TX and their real hot weather (105).
And i think it made a difference.
Old Dec 21, 2008 | 09:20 AM
poisx7's Avatar
....................5min edit rule
I meant Red Line Water Wetter NOT "some cool water " in the above comment/post
Old Dec 21, 2008 | 01:44 PM
sgmotoring's Avatar
Bleed Honda Blue
Get the pre-mixed 50/50 Honda coolant so you don't have to mess with anything. Regular water leaves deposits so you should mix it with distilled water. Plus with Honda 50/50, you got Honda blue running through your engine veins.
Old Dec 24, 2008 | 11:37 AM
MickeyTL's Avatar
I agreed with sgmotoring.....
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
