What does "Maint Req'd" light indicate?
Old Apr 21, 2003 | 10:08 AM
Mugen_Power's Avatar
I've seen this before...
What does it generally mean when this light comes on? What I mean is what should I take a look at first upon seeing this light? I just changed the oil last week, so I know that itsn't a problem. Can someone with the knowledge PLEASE HELP?!
Peace
Old Apr 21, 2003 | 10:13 AM
davo-cls's Avatar
aka davo-tsx
It's just a milage indicator (idiot light) that supposed to let you know when it's time to change the oil. You need to reset it when you change the oil, then it will start flashing again somewhere between 3500-5000 miles.
Reset it by turning the car off. Press and hold down the two trip odometer buttons (right side of the instrument panel). Start the car and keep the buttons pressed until they stop flasing. Done.
ferizzo's Avatar
still a Masshole
Is it flashing upon start up and then going out? Did you change the oil yourself? You may need to reset the maintenance required meter. If not it should be in the manual what the light indicates.
For example, my maintenance light is flashing when I turn the car on every morning but thats because its coming due for my oil change.
Old Apr 21, 2003 | 10:34 AM
CO-CL-S's Avatar
It means you should read the owners manual..
Old Apr 21, 2003 | 10:51 AM
gto2050's Avatar
Someday pigs WILL fly!
Maintenance required?
Old Apr 21, 2003 | 11:07 AM
I am RobG's Avatar
im back
i'm gonna go out on a limb here...but i think it means that maintence is required
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
