What do you think of 245/40/17
Old 12-01-2003, 05:16 PM
BBsAcuraRacing's Avatar
I have a 17 x 8" wheel with a 50mm offset, so clearance is not a problem. What about ride handling accceleration etc????
Old 12-01-2003, 05:21 PM
mattg's Avatar
i think it would work fine. your car may pull even more in the ruts though.
Old 12-01-2003, 05:34 PM
EricL's Avatar
Re: What do you think of 245/40/17
Better acceleration from lower effective gear ratio.
Generally lower inertial mass (better acceleration).
Wider footprint, but lower diameter means fit could be better or worse (if not lowered, it works on at least one members car [245/40-17 Toyo T1-S + 17 x 8" +48 SSR Type C]).
Slightly better handling...
Ask Technique if he is still around...
Old 12-01-2003, 08:38 PM
///M POWER
darrinb's Avatar
i'd go w/ 235 brian, last time i saw ur tires they looked like they had lots of tread, r u lookin for new ones now??
Old 12-03-2003, 06:44 AM
Yes Darrin,
I will be purchasing these soon. Probably the Michelin Pilots.
The nittos will be put on the stock rims for doing Autocross next summer.
Old 12-03-2003, 11:36 AM
///M POWER
darrinb's Avatar
oh i see, u still gettin the G cooupe
Old 12-05-2003, 04:56 AM
Don't know about the G coupe. It is nice not having a 600 car payment.
Plus I just bought a new winter ride so I'll be doing it up with sound and toys like the rest of my cars.
Old 12-07-2003, 03:07 PM
mattg....What do you mean by "pull in the ruts"
Old 12-07-2003, 03:23 PM
///M POWER
darrinb's Avatar
in like the groves of the road, the car will pull into them more...
thats what i assume
Old 12-08-2003, 03:55 AM
hemants's Avatar
245/45/17 is the correct size for the TL/CL
Old 12-09-2003, 05:32 PM
Actually if yo0u do the numbers, the 235/45/17 is almost EXACT match to stocks.... ie less than 0.3% error
Old 12-10-2003, 08:57 AM
hemants's Avatar
Depends which "stock" you mean. The TL/CL came out first so in all liklihood, the speedo/odo are calibrated to 25.685 inches (205/60/16) meaning that all Type S come with tires that are 0.2 inches smaller than spec.
I'd say 235/45/17 is clearly fine (25.3 inches) but 245/40/17 might be a bit small (24.7)
Old 12-10-2003, 12:37 PM
The anti-misshift
CCType-S's Avatar
I just brought a set of Toyo Proxy 4 235/45/17 and they are great.
Old 12-11-2003, 03:08 PM
EricL's Avatar
Some folks have tested their speedos and they were dead on with the 215/50-17s.
The loaded radius and/or revs/mile would be the best indicator of actual speedo error.
245/40-17 might be a tad small, but it has reduced rotational inertia, increased effective torque, and better chance of fitting with wider wheels.
It all depends on what someone is "going for"...
YMMV
MotionEffects
11-23-2009 01:27 AM
Tungo
05-21-2008 10:39 PM
shinybluecls
03-02-2007 01:32 AM
gman44116
11-22-2004 02:28 AM
POnca
02-17-2004 02:41 PM
Quick Reply: What do you think of 245/40/17
