???WFT??? check engine light
ok, so i started up my car the other day and the check engine light or maintinence required light came on and blinked for like 10 seconds, it did it again today, it dosent stay on so im thinking its nothing serious... anyone got any solutions?
I shave my change purse
my understanding is that it is just a reminder for you to bring it in for scheduled maintenance.
nothing to worry about. the dealer will reset the light after you take it in.
then again, I am a noob and probably have no idea what I am talking about
Poppin them thangs
Originally posted by NiteQwill
You can reset it yourself I believe
Before starting the car, hold down the select and reset button at the same time for 10 seconds.
Then while still holding them down, turn the ignition on but don't start the car
keep holding the buttons for another 10 seconds and let go
Turn the ignition off. The light should stay off now.
MP90 uninstalled
The ECU is just telling you it is almost time for service. perfectly normal.
Chaptorial is correct on how to turn it off. i think it will beep or something when it is done. not sure. get it serviced if you reset it though.
Jim
Jim
Actually up here in canada i have seen a few cl p and types s's have a smilar problem where the check engine light comes on and goes off for unknown reasons. Still trying to track down the problem.
MP90 uninstalled
The service engine light will come on and blink for a few seconds when you start the car if you are nearing one of your service intervals. The ECU in the car keeps track of how many miles you have driven since the last time the service light was reset. If the service light interval is 7000 miles, I’m not sure if it is but lets just say it is, then at about 6500 miles the service engine light will begin to blink for a few seconds when you start the car. Once you exceed 7000 without the service the service engine light will stay on all the time. If you reset the light it will stop blinking for another 6500 miles but you will still need service right away!
However, if your check engine light is blinking then you need to pull the codes from the engine computer. everytime it comes on, I am pretty sure it will record a trouble code. this code will tell you why it came on even if the light goes off.
Jim
Jim
Originally posted by ModAddict
If you don't reset the light, it will eventually turn solid instead of blinking, and stay on instead of turning off,..... I've been told.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
MP90 uninstalled
better late than never. I think I am about to go a few hundred over on a road trip. i am about due for the big 30000. the bastards want 478 for the service
Jim
Jim
That's what happen when you're not closing the oil cap tight. Remeber 3 clicks.
i changed the oil last at jiffy lube, they didnt reset it to my knowledge, is thats whats up?, ima get it done again anyways im commin on the 3500 mark for the oil, cars pullin to the right too, time for an alignment and balance i guess.
HeloDown
09-08-2015 06:51 PM
