wetter water
Lead Footed
Re: wetter water
Originally posted by johntypes
does wetter water work and if so how?
how many degress will it reduce?
Anyway, I put it my TLS and while the idiot gage is not a precise instrument for measurement, I did notice that the needle reads 1/2 of a line lower. Now how many degrees is that?? No idea.
Redline claims about 10 degrees. With our engines and tranny problem potential, it was worth spending the $7 bucks.
IMO
Ruf
Re: wetter water
2. See website: http://www.redlineoil.com/redlineoil/wwti.htm; it's explained there.
![](http://www.redlineoil.com/redlineoil/wwfig2.gif)
Happy CL-S Pilot
Damn... just add a pure water.... look at this chart... it is just like a bottled watter...
And there is an alternative:
![](http://www.designengineering.com/images/img93.gif)
http://www.designengineering.com/radiator_relief.html
And check this... the one who bought the All_motor custom turbo would love this:
![](http://www.designengineering.com/images/cryo-ics.gif)
http://www.designengineering.com/cry...r_sprayer.html
Capo di Tutti Capi
Originally posted by dfreder370
Intresting discussion, guys. But, I fear for you. When was the last time you changed your all important blinker fluid?
The kelvin-8 subzero bulbs always get changed with the blinker fluid (see manual). A smart car person knows to check the hysterious dust in the blinker well (without it, the bulbs will blink erratically and burn out prematurely).
Warning: Latest safety info says filling your high performance tires with dirty air can cause fatal crashes. Locate a good speed shop with clean, dry nitrogen for use in your tires. Your tires will thank you (one day).
AVOID tap or bottled “drinking” water in your car's radiator (OK, OK, if your in the dessert and need water -- go for it). However, it is best to put in distilled water or pre-mixed antifreeze (has distilled water already added). Tap and bottled water can have tons of crud that are not very "nice" to cooling systems. Bottled water != distilled water.
Plain water -- without any inhibitors (corrosion inhibitor) and lubricants -- is a disaster for long-term engine life!
(NOW I'm SERIOUS!!!)
Happy CL-S Pilot
Ah... sorry I meant distilled water.. in fact, the last time I added some distilled water to resovoir tank, I used the coffee maching to distlile some water.
One very important thing to remember if you decide to go this route.
This stuff is NOT an anti-freeze.
We use it in motorcycle racing because we are not allowed to use a glycol based coolant for safety reasons. (Glycol makes a track slick and is hard to get up in case of a crash.) More than one racer has suffered the results of not draining his radiator overnight this time of year at the track.
XSESIVE
What is the advantage to using the Mugen t-stat, Mugen fan switch, and Mugen rad cap along with the Redline WaterWetter? Does the t-stat open sooner? fan kick in sooner? and what about the rad cap.
Thanks,
David
Thanks,
David
Thanks,
David
Thanks,
David
No shit, guys. I dated a girl a long time back, her brother actually DID change the air in his tires every six months! And the way he did it killed me. He would go to the gas station and let all the air out of his tires and refill them, one by one. Curiously, he never broke a bead once. No jack, no nothin.
Although the above is true, in a more serious note, expensive airplanes DO fill the tires with dry nitrogen.
STL TL-S
09-23-2015 08:52 PM
