WD-40 and windows?
Old Oct 16, 2002 | 01:35 PM
russianDude's Avatar
WD-40 and windows?
I saw some posts where people from First Generation
used WD-40 to lubricate their windows so they don't vibrate/make noises on the way down.
I wonder if I should try to do the same on CLS...the window will probably get greasy and messed up.
In my previous thread a while ago - I mention that I am having driver window vibrating and making noises on the way down.
Any suggestions to fix the problem by lubing, or take it to the dealer?
Old Oct 16, 2002 | 01:40 PM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
Not WD-40, but silicone lubricant, you can get it at any auto store. You spray it inside, where the window comes out of. Works well, makes your windows a bit greasy the first time you raise them, but wipe that off and you are good. It lasts for a month or so and then you have to do it again. But, with our crappy regulators it's a necessity.
Old Oct 16, 2002 | 01:58 PM
Just pull window all the way down and spray silicone lubricant inside the opening?
Hmn, every month you have to re-apply this?
I'll try this.
Did you have the same problem? My window vibrates on the way down only....
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
