WD-40 and windows?
WD-40 and windows?
I saw some posts where people from First Generation
used WD-40 to lubricate their windows so they don't vibrate/make noises on the way down.
I wonder if I should try to do the same on CLS...the window will probably get greasy and messed up.
In my previous thread a while ago - I mention that I am having driver window vibrating and making noises on the way down.
Any suggestions to fix the problem by lubing, or take it to the dealer?
Not AtlCl98 or Atl-CL
Not WD-40, but silicone lubricant, you can get it at any auto store. You spray it inside, where the window comes out of. Works well, makes your windows a bit greasy the first time you raise them, but wipe that off and you are good. It lasts for a month or so and then you have to do it again. But, with our crappy regulators it's a necessity.
Hmn, every month you have to re-apply this?
I'll try this.
Did you have the same problem? My window vibrates on the way down only....
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
