Water Stalled My engine... PLEASE advise
Hi all, i was driving home today and came across this huge flowing water... yes i know i'm not suppose to cross it... but 2 cars infront of me made it ok, so i say, ok, I'm going to go for it. Half way across, i see the VSA lights come on, and i go "oh crap, i'm going to float now.." then I see some red and some yellow lights come on on the dash, and the car coast to a complete stop. So I'm stuck there, i call 911 and they say they can't help me cuz there's like 1000 houses being flooded right now. Any ways, i made it out fine and some people helped me push the car to the side of the road. but the car won't start anymore
If i try to start it, the engine makes one sound, then stops responding to the key turn. I think the electrical system is fine, the radio works, trunk still pops open, and the remote works too. Can someone give me some advise on what to do? I want my baby back!
Fuct in the hed!
The same thing happened to my sisters Celica GTS. It turned once, then nothing. She drive through a big puddle ( 2.5 ft deep)
........then end result, 3 bent rods and a cracked piston NON WARRANTY.
on bin laden
well, dont try and start it that's for sure. if there is water in the cylinder, you will definately break it. (guess that wouldn't be so bad, because then you can bore out your engine and get some new pistons & rods) ... but you need to take it in ...,on a TOW TRUCK.
- daemonichris -
damn and to think i was paranoid about going through water that went as high as my brake calipers this past weekend... my calipers were steaming... haha
Chung, are you the guy I saw on Mopac and exited onto Far West next to a couple of months ago?
Sorry to hear about your car, the storm around here tonight is some crazy shit. One of my coworkers got hit by a wave thrown up by the car next to him and it stalled his Honda CRV. He had to walk back to work.
I don't know what you should do, hopefully just giving it some time to dry out will help.
Hey, hows it going, I i'm the one in the silver CLS on Far West. I think I'm going to try to start it one more time later tonight, if it doesn't work, I'll get a tow truck...
Learn to swim.
Somehow I knew you were in Austin from reading the thread title, some weather huh?
Sorry about your car though, good luck. David McDavid is going to be real happy to hear from you...
tell me about it, i can't believe how hard it rained. Cars were going through that puddle before AND right after I stalled out. WHY ME!!!
congradulations, you may have just earned yourself a new engine!
When Houston flooded last summer, I was trying to make it to dry ground in a suburban (wasn't driving). Same thing happend, water got sucked into the engine. New engine. My father and his friend both lost their M5s. Engines were still good because they weren't running. You many have ruined your engine.
Well that time you tried to turn over the engine and it only cranked over once was probably a pistol trying to compress water, so you probably did even more damage by doing that than if you hadn't touched it after it died.
Either way you're probably looking at a new engine. Hope it's covered!
well if I were you id take at least take a look at my air filter and se eif it was wet or not, like really wet. showing a crap load of water that somehow got up in the engine. You could also check out the rest of the restrictive intake boxes, tubes, mazes for water. If you dont find any hopefully your allright when it comes to water. Sounds electrical to me though. gEtting water in your enigne is comparble to putting rocks in there. Uncompressable/ignitable. Thats BAD. good luck
-defrag
-defrag
Guys - you're forgetting the obvious. If he hydrolocked (the proper term -
) the engine, there would DEFINITELY be fluid leakage of some sort, and I seriously doubt it would even try to turn over.
If we had a distributor, I'd tell him to dry it out and spray silicone spray in it.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
if it was electrical, would it also mean that the audio system, alarms, windshield wipers won't work too? Or is it just engine's electrical problem? All the electrical componet seem to work for me. ie the sound system...
I think I'm going to call road side assistance in the morning![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Originally posted by mcdanjw
I'm going with electrical thing too... hopefully. Hope it's like getting the distributor cap wet. Just give it some time and it will work again!!
Hopefully that rain stays in West Texas!!
I sure as hell hope that stuff doesn't make it down to Houston, it was bad enough that we got hit once, we don't need to get hit again
Sorry to hear about your misfortune bros.
Honkey
It would seem to me that if you hydrolocked your engine it wouldn't even turn over. I'd guess you have an electrical short somewhere. I washed the engine in my Accord once and it wouldn't start afterwards. Turned out I had water in the distributor. All the electrical components (ie. stereo, wipers, etc) worked fine, just the parts that carried a spark didn't work. Also, in a really humid, cool climate I think it would take more than a day for that water to evaporate. Personally, I wouldn't start stressing about it yet, but it's definately a possibility the engine be have be shot...good luck.
-Aaron
-Aaron
Sorry to be the bearer of bad news, but it sure sounds like you hydro-locked the engine. Water on the outside of the engine and wiring hardly ever causes a miss, never mind a no crank condition. Water ingested in through the intake is usually always fatal. Have it checked at the dealer- easy to do- just pull the spark plugs and turn the engine over. It usually sprays the water out of the plug holes if the rods aren't bent so bad that it wont crank. If it is shot- call your car insurance co. I have seen them pay for many engines in cases just like this. It's worth a shot!
Good luck!
Good luck!
We just went to pick up my coworkers car that died after being hit by the giant wave last night, and it started up just fine.
Just needed some time to dry out I guess.
I wouldn't stress out too much yet.
Shawn S
Location: Somewhere between here and there, yet neither.
Good luck!
Good luck!
Okay here's the situation...from experience, I saw someone do it on a Turkey Day off-road meet in Hollister. One guy dumped his SUV straight into the water and cranked it....poof!!! The motor died....My friend did the exact same thing, except...he was a lot smarter....he had someone pull him out.....he disassembled his airbox and dried out everything.....and replaced the plugs....voila!! The car was fine...the mistake is to actually let in the water into the engine....which cranking does....
Originally posted by mrdeeno
wonder if insurance would cover it if you had a CAI?
STL TL-S
09-23-2015 08:52 PM
