Vtec not working...or is it?
Old Apr 27, 2006 | 07:05 PM
Paliplaya's Avatar
Ok well ive had my CL for about 3 months now, and i dont feel or see the vtec anymore. now this could be because ive gotten used to it, but my MPG says othewise...i get like 23-24...city. can i check vtec myself without taking it to the dealer? im over 50k
Old Apr 27, 2006 | 10:54 PM
typeR's Avatar
check the acctuator first then the oil level
Old Apr 27, 2006 | 11:06 PM
Lord Helmet's Avatar
I'm here in spirit...
Seems to be a string of these threads lately. I had one recently. Actually it was started by ghost_master. A member by the name of Night Rider (I think) had a theroy about the ECU causing it. Do you notice it ALL the time or only sometimes? Mine was only from time to time but something was definitely not functioning properly. It seems to have corrected it self since then. Try searching for that thread. It's probably only 3 pages back or so.
Old Apr 27, 2006 | 11:22 PM
typeR's Avatar
wouldnt put much weigth into the ECU therory it is entirely RPM based and oil pressure acctuated
Old Apr 28, 2006 | 02:32 AM
Paliplaya's Avatar
how do you check the actuator
Old Apr 28, 2006 | 07:48 AM
Check out this page... https://acurazine.com/forums/showthread.php?t=168429 It's in the link.
Old Apr 28, 2006 | 08:27 PM
Chopsie's Avatar
Beware of leakage
1-- Pop hood
2-- Start car
3-- Have someone rev motor oir pull throttle cable.
4-- Watch actuator mechanism turn or not turn.
Snaps's Actuator went out on the Auto CLS, and it was a night and day difference when the VTEC changeover occured. Now, the car still changed over to the VTEC Lobes with the actuator not functioning, but after he had the new working one installed, the car pulled so much harder. Without the actuator, driving a Type-S is like driving a Premium model (no offense of course to the Premium owners), just making the comparison.
Old Apr 29, 2006 | 07:31 PM
Paliplaya's Avatar
well the acctuator turns when i rev it, does that mean that the oil pressure find and thats its working, that im just not noticing?
Old Apr 29, 2006 | 07:55 PM
typeR's Avatar
just to be clear the acctuator and vtec engagement are two different things...but if the IMRC fails it will have a noticable affect on high RPM performance...next if it were low oil presuure from low oil level your car should fuel cut at around 4800 ROM when trying to make the hi lobe change over
Old Apr 30, 2006 | 09:07 AM
SIRSIG's Avatar
THE J35A2...
i think i felt this last night. i went WOT against a vette going 80 mph and at high RPM the engine hesitates, just like i let go off the gas. gotta check my oil level.
Old Apr 30, 2006 | 10:43 AM
typeR's Avatar
report the results this in its earliest stages will only be present from a 1st gear straight line acceleration or when making a turn
Old May 12, 2006 | 05:17 PM
Paliplaya's Avatar
my oil level is fine....i now i know there is def somthing wrong because an accord beat me the other day...by alot.
Old May 13, 2006 | 01:47 AM
VeeralS05's Avatar
I NEED MONEY!
I think mines fucked up too...I'll get the dealer to check it out this week before I head to FL... I need a full maintanance on my car...
Old May 13, 2006 | 02:44 PM
CLsuperhero's Avatar
I get the same thing from time to time. going 55 mph or above.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
