VTEC not engaging on 01 CLS?
NO, Chris didn't see me on Havana, the Legend actually is not driving right now. It needs a new master brake cylinder, so no brakes
I have seen a coupe just like mine in Boulder once too, don't know if it was the six speed. I'm not sure if the body kit is exclusive to 6 speed or not, and otherwise don't believe there are any cosmetic differences. Ghost, ya I can deal with most, I just want him there to kinda mentor, that was already included in price anyways. BUT.....It is essential you read my new thread as VAFC now becomes an afterthought....
Cl Hit! Totaled? Transition? < ----- This new thread
https://acurazine.com/forums/showthread.php?t=179548
Originally Posted by ghost_masterCL
he says he checked his IMRC and it clearly flipped when he revved it from under the hood. He says it alos is intermittent, so sometimes feels powerful, other times dead. Any chance that the IMRC is only working part of the time?
Originally Posted by typeR
this is late i know ,but your issue is starting to sound like a failing CAT
I've dealt with a bad cat before and I definitely don't have any of those problems.
Originally Posted by iisylentii
are you just saying that because your selling your car ?
The car is fine. I honestly don't know what it was. The only thing I can think of was maybe NightRider's ECU theory.
Originally Posted by aznboi2424
anyone around the 916 can come to check my vtec?
About...
https://acurazine.com/forums/showpos...1&postcount=18
https://acurazine.com/forums/showpos...5&postcount=23
Full thread about IMRC...
https://acurazine.com/forums/showthr...highlight=IMRC
See it working here...
http://www.geocities.com/gamesmgr/chod/acura/#Driving6
http://wizardsworks.org/chod/acura/pics/faq/actuator.rm
I can also here the IMRC kick in while driving. There is a slight change in how the engine sounds once it gets to 4k. It sounds like it is breathing better, and you should really feel the pull 4k and beyond of course...ALso check to see that little hose in the back towards drivers side is hooked up to the IMRC (aka Bypass Actuator Valve noted on the car itself)
hmm maybe i need to check both vtec (4800)and the actuator(3800) because i feel no difference throughout the rev band. (750 to 6750 rpm)
any one post pics of the actuator? so i know where it is?
Ok, apparently we are forbidden access to the server at which the videos of the IMRC/BAV are located...so basically without looking at the car it is right above/behind the back row of sparks/coilpack and near the sway bar. You can see it in this pic, near the strut bar directly up from "VTEC" on the engine cover. If you open the pic with microsoft IE you should be able to plus size it...hope this helps! You should physically be able to switch the little lever over. The most common prob is the actuator has teeththat get chipped and broken causing it to not be able to switch over.
http://i38.photobucket.com/albums/e1...r/DSC00499.jpg
In my last post (post #52) is the IMRC video. Unfortunately it's a Real Player video link so I'm guessing you have to have that installed. I don't have it on my work computer and tried it with Windows Media Player and it didn't work. It's the original vid from the Chod FAQ.How'd you make out in all the snow?
did yours fell smooth with broken teeth or without? cause i moved mine manually and it felt smooth. i also need to know where the IMRC is. pics would help. and could you tell me what acura calls the actuator and what IMRC stands for, im gonna being it to the dealer and tell them whats wrong.
I believe IMRC stand for "Intake Manifold Runner Control" (someone correct me if I'm wrong.).
As for pics, they are out there. Search the 2nd Gen CL forum for "IMRC" and you will find all kinds of info. Also, if it's important to you to see a working one function, if you don't already have it, install Real Player (I know, it sucks but do it anyway) and watch the video in the last link I posted in post #52 above. Trust me, the video works fine and it shows you what to look for when testing it yourself.
Oh, and mine always moved smoothly as I stated.
NR...Mr. Steve would be glad to send you a photo of the IMRC...just shoot him a pm...I'm at work with no camera...sorry.
EDIT:...I had a lapse in spelling the Ackronym
GM#2, does the CL-pee have an IMRC as well?
Since the intake horn on it is bored out/honed out...i bought a back up TB so I can send my TB to King Motorsports to be ported out...so my car will still be driveable
EDIT: But what's cool is that the J series engine has holes drilled for the IMRC to fit right in!
I'm not positive but I was under the impression the item circled is was activates Vtec...
Again, if I'm wrong or way off for that matter, someone please corect me.
im taking it to the dealership today, have them check it out.
the coolant and oil levels are good, but i cant find the vtec solenoid. does anyone know where it is so i can take a look. pics are a plus.
i checked the actuator today too, it flipped but im still not sure if it works properly since i have heard from other drivers that the plastic teeth inside can get broken.
I never get gas at a hole in the wall station. It's usually at one particular Conoco. I might actually start trying this Shell station instead for awhile.
IBankMouse
Jun 13, 2020 12:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
joflewbyu2
Oct 8, 2015 11:16 AM
well we will at least have my results from tuning a vafc :P
