VSA on or off?
Old Feb 21, 2002 | 08:25 AM
dsayad's Avatar
VSA on or off?
If when your tires slip and the vsa light goes automaticly. Whats the point of turning it on?
Old Feb 21, 2002 | 08:32 AM
fbazakos's Avatar
on bin laden
If you push the VSA button, and the VSA light turns on (meaning you have an orange triangle with an ! point), that means the system is OFF !
If you didnt push the VSA button, and the light is off, but flashes on when the tires slip, that means the system is working.
Old Feb 21, 2002 | 08:34 AM
Zapata's Avatar
Cost Drivers!!!!
Well it's a difference between the time you're tires actually start to slip and the VSA goes into action. Split second right? Split seconds can mean the difference between life and death. Leave it on except on take offs during a race
Old Feb 21, 2002 | 02:11 PM
louisn's Avatar
Re: VSA on or off?
PLEASE< read your manual. You have it flat-ass backwards. Light off-VSA on--Light on, it's off--
Only comes on when it's actually working which is not often but it may save your life.!!!!!!!!!!!!!!!!!
Old Feb 21, 2002 | 02:13 PM
dsayad's Avatar
so let me get it right.
Pushing the vsa button in to make the light go on is really off?
and that it only works when it start to slip?
Old Feb 21, 2002 | 02:28 PM
Nitin's Avatar
But I just got here
If you want VSA to help you out whenever needed, just make sure the VSA light is off when you first start driving.
Old Feb 21, 2002 | 02:30 PM
sorty's Avatar
Peace. I'm out.
Yup...if it's blinking, your VSA is working cuz your slipping, if it's just on, then your VSA is off, and that should be only when you're racing or if you're stuck in snow, not sure about the last part though.
Old Feb 21, 2002 | 02:52 PM
dsayad's Avatar
why should i have the light on in the snow. Dont i want the light to be off and come on it self?
Old Feb 21, 2002 | 02:57 PM
sorty's Avatar
Peace. I'm out.
Well I cant remember what the dealer told me exactly, but something about not using it in the snow or something, cuz when VSA activates it delivers power to one side, which mite get u more stuck....but anything that I was told at the dealer 2 months ago is just a a haze in my head now....too much experimenting I guess...
Old Feb 21, 2002 | 03:01 PM
dsayad's Avatar
it seems that i am just going to stick to
turning it off when i am racing. You think that it will be faster if off?
(VSA light on means it is off)
nice that i got my info straight
thanks
Old Feb 21, 2002 | 03:03 PM
sorty's Avatar
Peace. I'm out.
Here...as quoted from the sales brochure....
"...the Vehicle Stability Assist system on the Type-S helps counter skidding and plowing by breaking individual wheels to help restore the car to its intended path."
So basically VSA isn't intended so much for snow, it might actually be a bad idea to have it on while driving on snow...I could be wrong, but so far no one has come forward to go against this...
Old Feb 21, 2002 | 03:19 PM
sdho's Avatar
so off is on and on is off
...now I get it *doh*
I'm pretty bored
Old Feb 21, 2002 | 04:53 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
If you are driving the VSA light should be OFF... VAS is working snow or not snow.... VSA should be on!
Now if you are stuck in the mud or 20" snow and you can not move your cls cause of the slipping and VSA getting activated, turn off the VSA might help.
Old Feb 23, 2002 | 04:51 PM
fast_daddy_car's Avatar
If you are stuck in snow, you want the VSA on. The Traction Control is linked in with the VSA. If you have it off, then only the one front tire without traction will spin and you will sit there. With VSA on, Traction Control is activated, and if you are stuck it will apply the brake to the wheel that is spinning in the snow, causing the other wheel to move and pull you out.
Old Feb 23, 2002 | 04:52 PM
Type S's Avatar
Powered By HONDA
u turn it off when u want your tire to spin or smoke... for racing use purpose...
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
polish_pat
Sep 30, 2015 12:22 PM
