VSA, check engine, !
Old Aug 29, 2009 | 04:00 PM
marzoid's Avatar
7th Gear
I recently purchased an acura 2001 cl type S.
While I was driving the vsa randomly started kicking in.
It does this at all speeds even when I turn vsa off.
It also will sometimes keep climbing on the rpm meter without switching gears until I let go of the gas.
Ive gone to a few mechanics and the acura dealership.
Im getting different answers from everyone!!!
When im driving it will feel like my car all the sudden wants to go backwards this will happen at different speeds.
Ive had the codes read at the dealship they told me these could be from past errors.
erros where
Right rear wheel speed sensor
yaw rate sensor
ecm pcm failure
possible trans failure
sub throttle motor failure
Then i got the codes read a few hours later by a mechanic
and had the error
improper gear ratio
I pulled the fuses for vsa
and the car seems to run fine.
I also found out how to reset the VSA system
this is done by holding VSA button and brake down. And turning the key from position I to position II. I do this a few times and my car will run fine for awhile.
Then randomly it will start doing this crazy things again sometimes it takes a day sometimes a few hours sometimes a few minutes. It brakes out of nowhere and will throw the car back very scary.
I also read online that there have been many problems with the vsa chip. Can I bypass this chip?
Anyone hear of this before? I would appreciate any advice.
I really dont think its the transmission. When i have it in park and go through P,N,R,D5 it seems to switch over fine.
I read that the vsa chip may cause my car to keep climing rpm without swtiching gears and send brake signals
please help
Old Aug 29, 2009 | 05:53 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Best thing to do is pull the codes..
If u just bought it chances are the last person that owned it felt the tranny start to sputter so he changed the ATF and reset the lights and traded it in...
Very common to read someone on here that just bought a 2nd gen TL/CL and the tranny goes a week or month later.. I went through 3 I just got one rebuilt in NJ w/3 year 36K warrenty for $3000 Acura wanted $4100 ..
Where did u buy it ACura DLR and how long ago did u buy it most new car dealers have to give u 30 days 1k mile powertrain warrenty what state r u from?
Old Aug 29, 2009 | 05:55 PM
StonedCL's Avatar
B A N N E D
It might also be battery also ..batterys going dead makes cars do crazy things!
Old Aug 29, 2009 | 07:05 PM
marzoid's Avatar
7th Gear
actually when i bought the car he had the wrong battery in it
it was a private sale
ive replaced the battery to the correct one
its just strange
when i reset the vsa computer the problems seem to go away
Old Aug 29, 2009 | 07:43 PM
ThaTRUF's Avatar
when I had that deal, my codes were MAP higher than expected and TPS something or other. I replaced the throttle body (MAP sensor and TPS are a part of) and the problem was resolved. No tranny probs since the "fix" they put on the second gear back in 06/07 when they repl. my original trans. (83K). I am now at 131K and she rides as good as the day they put the new trans in.
I didn't go to the acura stealership to have the codes read, I went to autozone. No reason for them to "upsell" when they're reading them for free...
Old Aug 30, 2009 | 07:16 PM
marzoid's Avatar
7th Gear
stealership haha
its such a strange problem
my car has been running fine for the past 2 days
once in awhile it will climb the rpm meter and not switch gears
but once i let go of the gas it switches over
Old Aug 30, 2009 | 07:18 PM
marzoid's Avatar
7th Gear
how did you find out it was the MAP sensor and TPS
Old Sep 3, 2009 | 01:55 PM
PANAMARED's Avatar
sounds like tranny already slipping... did you confirm if yours had extra lube injector (2nd gear) installed? Try replacing tranny fluid see if you feel any difference. Obviouslly codes help... this is just my humble opinion
Old Sep 3, 2009 | 02:09 PM
gnuts's Avatar
3.5 psi
Where in hamilton are you? I grew up there, and am there most weekends.
Old Sep 10, 2009 | 06:09 PM
marzoid's Avatar
7th Gear
i figured out the problem!!!
it was my APPS
well im pretty sure thats what it was
i cleaned it reconnected the sensor and bam! it was all good
i feel stupid but i thought id post incase someone ever ran into the same problem
its located to the left of the engine
it had a cover on it
i took it off cleaned it
cleaned the sensor
i also made sure all the other sensors were connected properly and it seemed good after
the only problem i still have is the gear will not switch at 60km/h all the time
i have to let go of the gas for it to switch
this doesnt happen very often but once in awhile
i believe this is my transmission
but its not happening enough to really replace the transmission over it
Is there anyway i can prolong the life of my transmission since i notice this problem now?
could it possibly be something else since it is not a constant thing?
Old Sep 10, 2009 | 06:34 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i recently had those same 2 lights come on and I just rebuilt the tranny and it turned out pretty friggin good. My gears we burnt... literally they'd deteriorated over a milimeter in some cases. And yes it'll hold once ur in gear but it wasn't working properly.
anyways.. long story short.. the odds are it's ur trans going... and I got a guy who could do it for you ... same guy who did mine. He's an acura technician too.. and has been a mechanic since 1986.. so that's all I need to know..
Old Sep 10, 2009 | 07:28 PM
StonedCL's Avatar
B A N N E D
Prolong tranny??
Heat is a trans worste enemy so maybee a trans cooler/?
Also change that fluid!
Old Sep 21, 2009 | 07:54 PM
marzoid's Avatar
7th Gear
thanks for all your help
ya i might have to get your info if i ever need to rebuild my transmission
im gonna try to make this car last
i just painted the calibers blue this weekend looks amazing!
thanks stoned cl ill have to look into the trans cooler
sounds like a pretty good idea
especially since my radiator is smaller then the original
Old Oct 19, 2009 | 03:30 PM
apigo200x's Avatar
I will want to know or is the wearing of connections for scan my cl typeS 2002. Because the VSA is turn on all sensors are good thus I know more where to look at.
please help me thanks
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
