VSA, ABS warning lights due to ABS PUMP???
Old 01-04-2008, 03:12 AM
Registered CL-er!
smooth CL-in's Avatar
Exclamation VSA, ABS warning lights due to ABS PUMP???
Well, I went to my mechanic to have my tranny fluid change and i asked him if he can scan the car for any codes related to ABS & VSA warning lights. After the scan, 6 codes popped up and it was all related to the ABS pump. He couldn't clear the codes because the system detected that the car wasn't leveled. Has anyone ecountered this? The only cause I found were related to wheels sensors. The lights go out and come back on sparatically.
Back in the summer, I replaced all rotors, pads, brake fluid and upgraded to ss lines. Can the ss lines be the cause? He advised me to drive the car for a few days and come back for another scan to see if the same codes reappear. Has anyone had this issue?
Old 01-04-2008, 04:19 AM
2005 Acura TL
proudacuraownr's Avatar
I just had the pump replaced. It was under warranty thank God!!
Old 01-04-2008, 07:37 AM
ThinJim's Avatar
Those things are expensive for sure. You may need to take another look at your sensors on the wheels, but not seeing it, it is hard to tell. If you find yourself needing one, I have a good used one I stripped off a project car that works perfectly. Good Luck with it.
https://acurazine.com/forums/showthr...hlight=thinjim
Old 01-04-2008, 11:50 AM
Registered CL-er!
is that ur car in the avitar? how did it go bad? any mods?
Old 01-04-2008, 11:53 AM
Registered CL-er!
Thanks thinjim. btw how much ru asking? none of the codes were related to sensors. Where can i find the sensors on the wheels? how do they look?
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Stu2414
08-30-2015 07:30 PM
Quick Reply: VSA, ABS warning lights due to ABS PUMP???
