Vibration in Neutral/Park only
Old Jun 22, 2007 | 10:26 AM
sundevil_CL's Avatar
My car seems to shake a little from the engine whenever I am at a light with the car in neutral or if I'm sitting with it in park. When I'm in drive with my foot on the brake I don't feel it. New engine mounts installed about a year ago. Could this be my air-idle-control, or something else?
Old Jun 22, 2007 | 10:53 AM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Could be a number of things. When was the last time you replaced/cleaned your air filter?
Old Jun 22, 2007 | 12:37 PM
SuperTrooper169's Avatar
In the Mid-South meow
Mine does the same thing, as do a lot of CLs on here from what I've read in other threads. Is it just a very slight shake/hesitation every other second at idle? Do you have an intake or headers or are you stock?
Old Jun 22, 2007 | 12:39 PM
rtatsutani's Avatar
Never had a clean run
Hope it's normal b/c I have that too.
Old Jun 22, 2007 | 01:01 PM
Is the a/c on when you notice this?
Old Jun 22, 2007 | 01:25 PM
NEVERSUMMER's Avatar
EVERYTHING IS FOR SALE!
Same problem here..
So I sprayed just a little of carb cleaner in the hole of the throttle body going to the IACV and it stopped for a little then came back. It does suck.
Old Jun 22, 2007 | 07:36 PM
Car is stock...air filter replaced about 2500 miles ago. Must be a standard nuance of the car.
Old Jun 22, 2007 | 07:44 PM
Don't recall it ever happening for me. Only time I feel the idle rough is when I'm stopped at a light with the a/c on and the compressor starts.
Old Jun 23, 2007 | 01:36 AM
It's very suttle. I barely notice it unless I'm sitting in the car for longer than a few minutes.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
