Very Weird Grinding Noise
Lately ive been hearing a grinding noise when travling at low speeds ( like driveway, parking lot). The noise is coming from the front? Possibly and only happens for a few seconds...now i dont think it happens when im using the brakes but it happens only sometimes. Now i just did OEM front brakes and pads and i just did motor mounts
any ideas?
01 CL Type S auto.
any ideas?01 CL Type S auto.
Well update...took my pops for a ride...he says it sounds like a bushing that needs to be "lubed" ill take my brother out for a spin on saturday...it rianined yesterday and sounded worse...only when its damp out its loud.
Well since you changed brakes and wheels recently i would look into that first, unless you noticed the noise before then. I was getting a weird clicking noise from my rear passenger brakes after i had them installed but it went away within a few days.
I think it was before i did my brakes...but this car has had alot , alot alot of strange ass noises...first week on the road i got a nail in the tire, rear wheel bearing and motor mounts all go...
my guess is a sway bar link is going or ball joint.. but that should be evident.... mine similar noise was in the rear and I just took the liberty of putting on moog links and a rear sway bar instead (huge difference) and problem solved... and then some =-)
plus moog links are re-greaseable
open ur trunk and jump on the back.. try and get things to move... then u can see where it's at
my noise only occurred when goings slow also.. and only in certain situations
and moisture only made it worse... which makes perfect sense since it collects inside the end link where there is little or no grease and voila. u have ur culprit
is it from the front or back
but this is speculation... i'd have to hear the noise to say for sure you should replace it
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
