Valve Gap Specs
Old Apr 7, 2007 | 07:37 PM
New Image's Avatar
B A N N E D
Question Valve Gap Specs
Does anyone know what the valve gap specs are for our motor. both intake and exhaust. thank you.
Old Apr 8, 2007 | 02:29 AM
Allout's Avatar
Blown is Best
Intake 0.20 - 0.24mm
Exhaust 028 - 0.32mm
It's the same spec as the Accord J30 motor.
Old Apr 8, 2007 | 03:23 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
This is what I got from Chiltons online library:
and yes its the same as the Accord J30 specs (I'll give you the specs in standard in case your feeler gauge is labeled as such.
Intake:
0.0008" - 0.0018"
Exhaust:
0.0022" - 0.0031"
Old Apr 8, 2007 | 09:56 AM
typeR's Avatar
open the hood! now look up! BTW newimage your avatar...is that magnum or blue steel
Old Apr 8, 2007 | 12:58 PM
kyle77777's Avatar
Gonna cost to catch up
I think its Le Tigra
Old Apr 9, 2007 | 10:45 AM
typeR's Avatar
magnum blue steel le tigre it's the same look! i feel like im taking crazy pills! it's the same look!
Old Apr 9, 2007 | 09:51 PM
ed231's Avatar
Just out of curiosity, can you adjust the valves on the 3.2 CL-S engine? I was told by the dealer that the valves automatically adjust themselves, is that right?
Old Apr 9, 2007 | 10:09 PM
Nope, they still need adjustment, however the plan was to make them so they wouldn't need adjustement until the first major tune up at 105,000 miles.
http://www.hondanews.com/categories/781/releases/629
Originally Posted by Honda News
105,000-MILE TUNE-UP INTERVALS
The CL boasts engine tune-up intervals of 105,000 miles, between which only routine inspections and fluid changes are required. The roller-follower design of the VTEC valvetrain cuts friction and wear to the point that the screw-type tappet clearance adjusters do not require inspection until 105,000 miles. At 105,000 miles, the platinum-tipped spark plugs are also due for replacement.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Tribalheads
Sep 29, 2015 03:24 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
